hey;
Car Info:
S1 R33 Skyline Rb25det 100,000km+
Rb20 Turbo
FMIC
Air-Filter
Exhuast
EBC
Ok so here is my problem, my car was missing when i was turing on boost and running 0.8bar (started to happen about 1-2mins after running the car hard with boost on) with the ebc and running stock boost the car would not misses, i would run it hard all the way to redling and it wont have a problem;
So this weekend i change my plugs as i am running in a drift event this week and i need to be able to run boost.
Now i put normal Copper plugs, and gap them to 0.6; Taking it for a test run the car started to misses in every gear above 4000rpm on stock boost, with 0.8bar the car misses as soon as it hit 0.8bar on the boost gauge.
So i took them out and regap them too 0.8 and it has the same problem as above,
Now i check my old plugs they were gap at around 0.5.
I am majorly confused because before i change the plugs it would only miss under the condtion of 0.8bar of boost now it happens under stock boost.
What else could the problem be and how can i check if it is that, i will be taking the car to the mech 2morrow but i wanna get an idea before then
Thanks Michael :D
https://www.sau.com.au/forums/topic/92974-miss-firing-problem-plz-help/
ok
Today i replaced my new spark plugs with my old platium plugs (which had only done 20,000km)
THAT FIX THE PROBLEM!,
IT NO LONGER miss firers on stock boost BUT
when i turn boost to 0.8bar the car MISS firers from only about 4000 to 5000rpm THEN it just stops and goes all the way to redline without a problem.
apart from that 1000rpm the car feels fine, goes hard and doesnt feel like its losing any power (and this is backed up by the figures i see on my blitz power meter)
im SOOO CONFUSED!!!
the stock ecu has excess airflow protection which you will most certainly hit running 0.80bar boost. try it at about 0.60bar boost and see if you get the same problem. the stock ecu picks up too much airflow via the airflow meter and cuts the timing, which results in flat spots
mate your going to have to upgrade ur ignition system. Split fire coil packs are great for skylines with some boost. a lot of people say that thestandard coil packs can handle a lot of boost. I personaly dont believe that cause as soon as i boosted mine to 10 psi it was missin and back firin constantly. Got the new packs and problem solved. But there not cheap!!!
My R32's running 1.1bar with a VG30 and didnt missfire ever, still doesnt....and thats with the standard coilpacks, the only time it started was when my spark plugs basically disintegrated, got new platinums the the right heat range and bobs ur uncle she's a goer, still no missfires and can run more boost if need be. (dont want to though) but do as paulr33 suggested....
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
