ok guys after long deliberation with my girlfriend i have finally decided to let go of my 180 =[.
- Sr20det
- Manual
- Sunroof
Engine:
- Front mount
- 3" zort all the way
- walbro fuel pump
- fuel regulator
- greddy profec b II
Drive/ suspension:
- Front strut Brace
- Locked diff
- tien HR coilovers
Exterior
- 17" rims (not on atm, but i do have pics)
- Gp Sports front bar, Vertex side and rear
Interior
- kenwood deck (unsure of what type but is pretty)
- us audio all around (cept deck)
- mo mo steering wheel
- drift button
ok ive had the car for nearly 2 years i have much looked after the car, as much as i do love the car its time for me to move on to something different as this is the 2nd 180sx i have owned.
The car has always been serviced when an oil change is needed and also i have always got major service (oil, oil filter, sparkys, fuel filter) every 3 - 4 months. Since november the 11th of last year i have had the engine replaced with a fresher engine at the time i was told by my mechanic it was in the mid 50k mark since then its been off the road (s15 face lift THAT DIDNT GO THROUGH) so i would have roughly driven it 10 - 15k since the engine was put in. The car outside is in fairly good conditon. body wise it is straight, no scratches no dents whats so ever, i have recently (2 months ago) got the car sprayed in matt black (looks sweet/ tough) i might add. Altought the car may look drifty (locked diff) i will assure you 100% that i have never drifted on the streets nor on track just a wannabe.
inside the car does have a few cracks on the dash, but if a true buyer does come along i will source them with a dash that is scratch, bullet, cum, whatever you want proof. I am very open to any sort of compression test as i know the engine is mechanically A1 also the turbo has no shaft play what so ever, i know this because i had all the gaskets (head to manifold, manifold to turbo, turbo to zort) changed 7 months ago and we had a really good look at the turbo all shmick and shpan.
i am hoping the next owner will treat it with the same respect i have as this car has no given my any major problems, the only major problems i have had with my car is injectors maxing out =[. Rego on the car is running out on Nov 11th this month however if rego is required it will be 15k =]
i am also interested in a trade for a r32 gtst manual, if not 14.5k as is or 15k with new rego. also the car will be coming with 17" lenso c5 copies.
Contact details:
Shaun 0423281569
msn me : [email protected]
pm me
im from sydney i would prefer sydney people, but interstates are welcome GO SYDNEY
http://i21.photobucket.com/albums/b262/min...us/DSC00306.jpg
http://i21.photobucket.com/albums/b262/min...us/DSC00307.jpg
http://i21.photobucket.com/albums/b262/min...us/DSC00315.jpg
http://i21.photobucket.com/albums/b262/min...cus/engine2.jpg
http://i21.photobucket.com/albums/b262/min...roofitstein.jpg
Edited by LZYSKY
2 months too early!! If this is still around in late dec I'll take it. Ain't holding my breath though. Very nice looking car, sure someone will snap it up soon! :(
Best of luck with the sale, if its still for sale in dec i'll be getting in touch with you for sure
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
