Do you dorfit?
I was thinking about this the other night... what could possibly motivate someone to push their car to the very limit and beyond... cause untold damage to it and run such a high risk of crashing and or mechanical strain/failure :)
Then again.... driving in a straight line just dosent make any sense :) :twisted:
[b:309d744247][i:309d744247]Why do you drift ?[/b:309d744247][/i:309d744247]
https://www.sau.com.au/forums/topic/93-why-drift/
I do it casue it shows control and is right on the edge and you don't have to be doing 160-200 kph. Its really interesting my advise is to practice at low speed in the wet first get used to hanging you back out and learn to feather the throttle. and to keep it under control.
then you can learn the otehr tricks like using the handbrake to start a drift or clutch lock.
power is not important when my car was N/A @ deca alot of people were surprised.
and an option vid I have the winner of the drift competion is driving a 92 ps ae86.
meggala
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2450
Guest 33GTS25
everyone has a different point at which they glean excitement from driving a motor vehicle.
i personally have a few roads that i travel fairly often(as most of us do) and i try to take corners at faster speeds each time i am on them, some are long sweepers where others are negatively cambered or even those bigass roundabouts that just scream out to be pushed
my point is that we all like to push the envelope to find where our ego starts and our ability finishes hence the reason i like all forms of motorsport from drags to track and drift
plus its always a good way to upset significant other :twisted:
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2451
Guest [ryan]
Drifting isnt the quickest way of turning a corner either.. sure it looks impressive but i dunno =]
I was playing my friend on GT3 the other day, I was drifting like nuts in my 180sx whilst he was racing like normal - he kicked my arse
i raced him again driving properly and beat him by 10 seconds
both had identical cars....
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2452
Drifting isn't to go faster tho, its a style. There is no way that you could EVER keep up with an identical car taking racing curves.
I personally haven't ever gone drifting in my car, i have had it slightly sideways before, but not much... i am a slow driver and am already too scared to damage the car as it is..
if i go to the track on the 16th, i will whack the stockeis on and try.
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2454
O.K guys heres my take on drifting... sorry Do ri fu to
Back in 1994, I was living in Kobe Japan on a working holiday with my Relatives. I was working at a 5 star hotel and made many friends while there. Most of them were car nuts like ourselves and their cars included 91 R32 GTR, S13 silvia, Trueno and R32 Gtst. Most young people under 25 in Japan dont drive around in new cars and drive Modded chu- sha ( second hand cars)
A friend of a friend showed us of drifting action from Osaka on Video and they would try to copy their moves in their cars. Its basicaly a fad that someone started and everyone has copied.
Yeah its fun, hard on Ur car and a good way 2 chew up Ur tyres. Its like rallying on tarmac.
Personally, i'd enjoy drifting using someone elses car :)
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2455
thanks akira
your right about the tyres thats why I use s/hand stuff at $60-70 each.
there is a lot of skill required to do it right you should practice in an open area like a car park first so you cant hit any thing. practice getting the back out and how it feels and learn to catch it don't worry about speed or any thing yet just take your time. then as you get better with more confidence you will be able to go faster and faster. but alwaysstay in controll.
meggala
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2456
  • 3 weeks later...
I drift my car every chance I get!
I love feeling of that car slide around the corner...
especially when road is wet my atessa system work over time! :)
it's not really about how fast you turn corner, it more than that. it's how you turn corner with style...
ps. People behinds look at you like teenager dickhead! there he goes! LOL.
FYI I never had accidents of any kinds, I know my limits and there is place for everything!
Some one BUY ME NEW TIRE!!! :) being 4wd my tires chews up quite a bit!
cheers
Joe
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2458
I don't know about others, but my definition of drift is sliding completley through a corner - from entry to exit. Thats also the same definition that the japs use, if the anime Initial D is anything to go by. Given that, I've never drifted in my life but I sure do powerslide out of corners a lot 8)
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-2461
Guest [ryan]
Ever since seeing Initial D i've been hooked on Drift.. I used to like it before that, and was pretty curious about what it would be like.. But now i'm just plain hooked. Initial D has sparked a love for the AE86 for me that's for sure, hehe.
Check out this one (See attached Image)
=Ryan=
https://www.sau.com.au/forums/topic/93-why-drift/#findComment-15257
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
