Just a couple of questions:
What actuator are you running? As the spring may be a bit weak
What comp ratio are you running? As you have a built engine (so can specify the compression) and metal head gaskets come in a range of thicknesses (so can further alter the compression).
One other thing worth noting as well, your dyno runs have the intake temp at 40 degrees and the room temp at 20 degrees. Please tell me you were running with the bonnet down as otherwise you are probably making less than 210 and the figures have been skewed.
Mechanic(whom built the engine) said compression around 8.0.1 or there abouts.
Yes Bonnet was down/closed, tuner said it'll give more realistic figures so that can justify the extra heat.
actuator? Whats that again? Is that the spring on the turbo which adjusts the boost? Well i'm running an apexi avc-r (current model) if your refer to boost solonied.
Internal Wastegate in turbo,
also forgot the mention (tomei/or sard fuel regulator can't remember)
I only asked about the compression because it's a lot of boost for that sort of result, where as a lower comp engine would require a little bit more for the figure.
The actuator is the bit bolted to the side of the turbo that looks like a cylinder with a rod sticking out of it that attaches to the wastegate flap. If the actuator spring is too soft (which i suspect it is) then the AVCR wont be able to hold boost no matter the duty you run. It's not the stock one is it?
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
