  • Replies 146
Thats fine for them. But is there any low mounts running tens in  australia on street tyres and pump fuel ??
come on simon u know low mounts r superior to a big single haha jk :lol:
anyway good result mate, and when u gonna get it on a real dyno (4wd) and wind it up properly, stuff these shops without the right equipment :)
