im looking at getting a new exhaust manifold and have been looking at alot of different sites with different styles.. one thing i noticed is where the turbo mounts, one style has all 6 runners going into the mount with one big mounting hole, and others have runners 1,2,3 going into the mount and 4,5,6 going into the mount sperate, with the mount having 2 seperate holes instead of one (split pulse i think it is) .. anyways what is the difference in these 2 if any? is one better then the other?... cheers
https://www.sau.com.au/forums/topic/93098-manifold-question/
The OE manifold separates 123, 456 groups until the turbine inlet flange. Most likely an effort to stop the pulses from each group affecting each other.
A true split pulse system should carry the separation into the turbine scroll. Check the pictures of a GT3271 at turbobygarrett.com as an example.
Try a search on this forum and also Google for split pulse turbine.
It's done in an attempt to keep a large-ish (high flow capability) turbine that responds as a smaller one does. The idea is to maximise the pulsing effect that comes with the two cylinder groups. The firing order and layout of an I6 are evidently best suited to using this spec, but I think they do it with rotaries too.
Do a search and see what you come up with.
cheers
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
