so leave the std compression i got a high mount so thats goin on and port and polish should help wats the pistons to get pplz
Mate that is a question for your engine builder (i assume you have one)
Its not a simple case of buying pistons and dropping them in.
You need ones that suit your clearances/bore size and whatever else.
Am I the only one here who thinks this sounds a bit sus?
Nismoid - You've normally got your bullshit detector switched on.
im working nightshift and im on-call... so im lacking on sleep at the moment.
Radar off until monday :(
thankyou leigh im sorry if this sounds a bit suss not all cars are the same ill post my dyno sheet if you like the curve isnt to great but i had a great cure with only bout 275kwkw and by the way it was without a ebc just a bleed tap
there is nothing wrong with the t70 tell me why you dont belive this t70 i have wont make power
and yes thankyou my mechanic is helping me but im just checking all my options before i go ahead with it all is this wat forums are for to find other opions from ppl that have being there and done it all
thanks leigh promise you will be passanger to this vechiel when it gets out not just a onlooker on the dyno like all the rest rofl
