Does anyone know approx how much or where to buy turbo to cat exhaust?
I was told mine was turbo back but i had a look (should have done this before i actually bought the car) and its only cat back --> pointless
It is 3 1/2 cat back, does anyone know how much to complete this (turbo to cat?)
and if it is worthwhile doing that or just buying the complete turbo back setup?
Cheers
https://www.sau.com.au/forums/topic/93113-turbo-cat/
Cheers
BATMBL on this site has very nice "turbo to cat" pipes for sale in the business traders section of this forum for around $400, I have one and it is good! Make sure you get a hiflow cat too
https://www.sau.com.au/forums/topic/93113-turbo-cat/#findComment-1679979
forget jastjap search ebay you can pick up a front pipe 3" for around 200 dollars delivered and the buy the dump pipes from jastjap for 400 or so total 600approx jast jap are selling the complete kit on ebay for 1000. save yourself some dollars.
now i have been told you only need 3 inch to the cat then 3.5 inch after becaues after the gasses cool down they need the extra .5" room to flow, thats what i have been told. i am open to any other suggestions or ideas on this one...my thought was as gasses heat up they expand as they cool they become denser
Edited by dejanz
https://www.sau.com.au/forums/topic/93113-turbo-cat/#findComment-1707987
I've got a used 3" dump and a 3" titanium front pipe available if you dont want to spend alot. Why did I remove them??
Can't tell a lie I removed them to install a Batmbl one piece split dump/front pipe...very nice and great value.
https://www.sau.com.au/forums/topic/93113-turbo-cat/#findComment-1708000
if you are talking about r32/r33 gtst dump pipe and front pipes, then i sell them for $395 (mild steel) and $450 (stainless steel). much cheaper than any of the options above.
these are the split wastegate systems, not the ones with a single large hole at the dump. it is a dump pipe and a front pipe in one piece, not 2 seperate parts which will require an extra gasket and a possible future exhaust leak at that point on the exhaust.
the wastegate pipe on the split dump pipe (2 piece systems) is too short to be effective in reducing turbulence. you need at least 35-40cm seperation before they re-join.
https://www.sau.com.au/forums/topic/93113-turbo-cat/#findComment-1708010
im in a similar situation as you, stock dump/front and huge cat back exhaust. had a look around and saw BATMBL's pipe. looks just as good as any other and got him to ship one to me just last week. will hopefully be getting it put on this week.
honestly i was quite surprized at the quality. i was so excited i showed my mate and even he was amazed at what i got for the price i paid. i cant wait to get it on!
https://www.sau.com.au/forums/topic/93113-turbo-cat/#findComment-1709280
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
