Hi everyone, I am a lurker here at the Skyline forums. I'm trying to find people who might be interested in :
Item: Prince GTB Triple Weber manifold
Item Condition: Used, but in good original condition
Reason for Selling: No car, and webers are gone too
Price and Payment Conditions: $750.00 ONO
Extra Info: Also have top linkage bar and rose-joints, but not the 3 x adjustable linkage struts that go from the bar down to the carbs
About 1980 I bought it from an old guy who owned and crashed his GTB. He had stored it for about 10 years, and I've stored it about 25 years, so it's almost brand new :-)
It was fitted with 3 x 40mm DCOE Webers. I used the Webers on a very hot Holden Red Motor (horrors), then much later I sold the complete Holden motor to a guy to use in a speedway car. That left me with the old Prince manifold...
Please send me an email to discuss it further. I have absolutely no idea what it might be worth, but to comply with the Posting Rules (which says I need to state a price) let's start it at $750.00 ONO which might be a silly price, or maybe a bargain :)
I've kept it so long that I'm not really in any hurry to sell it - but please make contact and we'll see what we can do.
Contact Details: Please email me at :
[email protected]
or
[email protected]
PLEASE NOTE : I only visit here occasionally, so you're far better off emailing me than replying to the thread or PM'ing me here.
ALSO NOTE : the pic I have attached is of an identical manifold owned by someone else. It is NOT the one i have for sale but will give you an indication of what it looks like.
Cheers, John
Edited by JohnC
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
