Xbox - Mod Chipped with 2 Games + Controller - Sydney
Xbox - Mod Chipped with 2 Games + Controller,
Xbox has been Mod Chipped, LPC CheapMod, installed with EvolutionX, media Player, DVDx. It can play everything from DVD's to vcds, svcd, divx etc
Comes with Project Gotham Racing, and Test Drive installed on the HDD.
Has never been used, straight out of the box, straight modded, straight to you.
$550..
Email me on: [email protected] - or call 0414 678 944
the games are copied to the harddrive.
its the standard xbox hard drive, 8gb,
i format the f: drive so you get an extra 2gb. of free space
I can install another bigger hard drive if you want, you supply or i can supply it. either way.
