Hey all,
just wondering which petrol you all choose to use and which petrol you reckon is the best? i know this has been talked about before, but i think it makes for an interesting discussion.....
i currently only use BP Ultimate, but am thinking of making the switch to the Mobil Synergy 8000 (spelling?), as it has now become avaliable in canberra. which of these too would be the better fuel?
https://www.sau.com.au/forums/topic/93155-which-petrol-do-you-buy/
Im not a skyline :) ,but front the same issues with fuel I'd imagine. I get BP Ultimate first choice and Synergy 8000 second. I find those 2 both equally good fuels, so long as they are from high turnover stations. Synergy is usually just a bit dearer. Optimax if desperate and only enough to get me out of trouble.
i heard somewhere that Vortex 98 is just re-badged Optimax...... :)
do they use ethanol in 98 ron fuel? i read a press release that stated ethanol was only used in the regular unleaded. i wasn't at the launch, so correct me if im wrong......
Edited by Frink
Bp ultimate, runs the best... ive tried synergy 8000 and found it gets hardly any kms out of it.. but runs awsome!!! (Only just released a few weeks ago here)... optimax if its only what i can find.. the car hessitates on this fuel though, and anything less then 98.. so i try my hardest not to put it in.
Dayne
Hey all,
I use Ultimate. If I fill up with Synergy 8000 I get poor performance and the ECU pulls timing and activates the boost cut to lower the boost to 0.7bar occasionally. I never have this problem with Ultimate.
I will never touch Synergy again.
it's funny cause in the GTI-R and Soarer and the GTR too I've tried:
optimax
ultimate
synergy 8000
I can't really pick any difference between the three. if i had to choose a winner i guess i'd say synergy 8000 but that could just be the placebo effect of it being the most expensive of the 3. I've certainly never experience any poor running on any of the above.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
