Hey all,
just wondering which petrol you all choose to use and which petrol you reckon is the best? i know this has been talked about before, but i think it makes for an interesting discussion.....
i currently only use BP Ultimate, but am thinking of making the switch to the Mobil Synergy 8000 (spelling?), as it has now become avaliable in canberra. which of these too would be the better fuel?
https://www.sau.com.au/forums/topic/93155-which-petrol-do-you-buy/
Im not a skyline :) ,but front the same issues with fuel I'd imagine. I get BP Ultimate first choice and Synergy 8000 second. I find those 2 both equally good fuels, so long as they are from high turnover stations. Synergy is usually just a bit dearer. Optimax if desperate and only enough to get me out of trouble.
i heard somewhere that Vortex 98 is just re-badged Optimax...... :)
do they use ethanol in 98 ron fuel? i read a press release that stated ethanol was only used in the regular unleaded. i wasn't at the launch, so correct me if im wrong......
Edited by Frink
Bp ultimate, runs the best... ive tried synergy 8000 and found it gets hardly any kms out of it.. but runs awsome!!! (Only just released a few weeks ago here)... optimax if its only what i can find.. the car hessitates on this fuel though, and anything less then 98.. so i try my hardest not to put it in.
Dayne
Hey all,
I use Ultimate. If I fill up with Synergy 8000 I get poor performance and the ECU pulls timing and activates the boost cut to lower the boost to 0.7bar occasionally. I never have this problem with Ultimate.
I will never touch Synergy again.
it's funny cause in the GTI-R and Soarer and the GTR too I've tried:
optimax
ultimate
synergy 8000
I can't really pick any difference between the three. if i had to choose a winner i guess i'd say synergy 8000 but that could just be the placebo effect of it being the most expensive of the 3. I've certainly never experience any poor running on any of the above.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
