from memory, u gotta pull bottom part up outa its clips frist then slide it outwards.
then to do top part u remove to bolts at bottom at each end then slide it up off its hooks, just becareful when putting back in that u don't bend the hooks otherwise will be harder to put on.
  • 4 weeks later...
That is the correct way to remove them........if the base has been in there a while it can be tad difficult to remove.
Basically you just need to sit behind you Front seats facing the back of the car......in a squatting position....then push the front of the base towards the back of the car and upwards at the same time.....it will then release......i have had some seats that required a bit of coaxing with a long screwdriver lol.
The to remove the backrest, just follow the instructions given above by skypy
