I dont do air con "fixing" but whatever parts you need I can get pretty cheap.
If you need to go to someone who does aircon, I would recommend Tuggeranong Auto Electrics, the guys there are really cluey and good with Jap cars... If hes there you should try to speak to Stuart. :D
  • Replies 63
Oh, I would need to know exactly what the pipe looks like and what side it is on the air con system, then I would need to know what kind of fittings it has on either end (beadlocks, o'ring, pad or flange) then once you had the new pipe on it would need to be regassed anyway, and if its not R134a gas then its R12 gas and will have to be changed so you might need a new reciever drier aswell.... Complicated enough for you?
Heh heh :D Sorry I just like to prove how car smart I am sometimes... If you go to Tuggeraning Auto Elec they'll know exactly what pipe you need, then they'll call me and order it... So ill be getting it that way anyway :(
Well, its been nice being able to log on here all day recently but I wont be able to from tomorrow as the user of this computer will be returning to work and I will be forced to use the other computer again (which has no internet) so I will only be checking in after work... Just thought Id let you know :D
I thought so, I see your car everytime I go round to rinse off my car ( I park under a tree at work)...
I havent seen you do anything stupid yet :)
I work at Ingrams on Townsville street, pretty much straight across from the post office.
If you ever need anything Auto electrical or air con, drop in and see me, ill look ater you cos your a Skyline man :P
thanks man is there anyway to fix the dodgy off button on the 33 if anyone else has had the problem when it tilts to the side and doesn't work anymore
and yeah you would see me alot I'm addicted to the sausage rolls from the bakery next to the news agency
Slither, you work in Fyshwick dont you... Just off of Canberra Ave.
I see your car heaps.
Hi Slither:ditto R31DET's comment-spotted you car a number of times. VERY neat,I'd say. Top colour,too! Congrats!
Yeah mate i've had this problem. what happens is the button has a hinge that attaches it from the top allowing it to be pressed in. this has broken. oyu just need to either glue it back together, or what i did, was glue a bit of plastic behind it to stop it rotating. if you pull it off you'll see what i mean.
Just checked this thread again thanks for complement
as for the button sounds like a bit of effort to pull it apart think i'll just put up with it always been on
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
