Do they come in a packet? Please confirm that they are indeed a genuine item, or edit your post if you cannot clarifty this so that you can avoid any confusion among potential buyers.
Thank you
I've again updated the post for you. I've sent an email requesting to know if they are genuine or not. Waiting to hear back now.
  • Replies 130
Posted Images
All PM's have been replied to.
Those that have requested a lanyard or more above since my last post, a PM with payment details has been sent to you.
Those that have made payment and payment has come through this morning for those, your payment has been noted in my spreadsheet.
Guest
