I was wondering if anyone has transplanted a rb25det into there R32's at all. I've got an N/A R32 being imported and was going to go with just the nice and easy RB20DET engine swap and use the apexi ecu to control things but the better box and better engine getting an R33 halfcut and doing most of the work myself sounds like an interesting project to do over the xmas period.
Any help/assistance would be much apreciated.
https://www.sau.com.au/forums/topic/93180-rb25det-r32-conversion/
  • 2 years later...
I just got my RB25DET (series 2) and I was hoping you could help me with some questions.
My Skyline is non turbo so it will be a big step with the RB25.
Now then, my first question is about the gearbox mounts, I hear they aren't the same and I will also have problems with the speedo meter. What do you know about this? Can I use the Xmember of the R33 ??
The second is about the harness, everyone that has ever swapped an engine told me that the harness is the most difficult part of the swap. Do you have the diagram of the R32 and the R33 (still can't find it for the R32) and some pointers on how this is done??
Hope to get a reply from you soon
Carlos Rudolph
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
