Hi guys, i am looking at removing the HICAS off my r32 gtr, the lock bar is fine but what i was wondering is wether the R31 power steering pump would work as a replacement to the 4WS R32 one without any/many mods making it a straight conversion to 2WS? and allowing me to remove all the piping or would i need to still do modifications to the rack or other areas?
i have searched, but haven't really found a sound answer to removing all the piping, i have heard of removing the rear seaction from the power steering pump and plumbing it up, but i have also read that it could possibly overheat?
so any information would be really useful, thanks.
https://www.sau.com.au/forums/topic/93183-removing-hicas-on-r32-gtr/
When you botch up the 4ws pump they eventually wreck themselves I have proven this to myself many times. so a 2wd pump is a must.
can remove all pipe work associated with hicas system, dont forget the hicas pump in the engine bay its not needed.
lastly a r31 pump would be okay they are fairly big units is the only downside but I am guessing it would work, just check the pulley size is close to the r32 4ws one and it should be right!!!
with that being the case am i right then in saying that for a 32 GTR a tomei hicas lock kit is an easier/neater option?
I was going to go the lock bar route and like the idea of the weight saving, but i don't particularly want to fark around with the power steering too much. The tomei kit is a just 2 shims and a little module to cure the warning light/heavy steering problem.
hmm, true, but my engine is out at the moment and i diddnt really want to put the 4ws plumbing back in when i put it back together...
however if it proves a hugely easier option then i will...where would one source one of these tomei kits from out of interest?
I don't know how many times I have posted this up, maybe we should make it a sticky..........
The R32 power steering pump has 2 stages.
The front stage works the front power steering rack, leave it alone when removing the HICAS. It will function exactly as is intended.
After you have removed all of the HICAS stuff, the rear stage is very usefull for pumping power steering fluid through the standard power steering cooler. All you do is use a short piece of hose (not high pressure) and 2 clamps to join the ouput of the pump up to the cooler. Takes about 2 minutes.
This is much simpler and more effective than rerouting the front hoses so the returning fluid (not under pressure) goes through the cooler.
I have done this on 10 or so R32's over the years, never ever had a problem. The pump works fine and the power steering fluid doesn't overheat. On the race cars we use auto tranmission coolers on the power steering fluid (instead of the standard loop of aluminium pipe) as they get quite hot in a racing environment. This is not necessary on a road car, the standard loop does the job.
Do a search if you want more details.
:) cheers :)
Edited by Sydneykid
thankyou SydneyKid, thats the information i was trying to find, i have read heaps of threads on how it wont work, etc, but this is the first one i've found on rebplumbing the pump without it overheating and the such...
or you could do what i did and pull the back of the pump off (4 bolts) and slide out the little vane thing inside the pump. and put the cover back on. and block off the inlet on the resouvoiur and the outlet on the pump.
then remove ALL of the pipiing associated with the hicas.
steve
SK-  Are all R32 4WS  pumps the same??
I have not come accross any different ones. There may be, but I have never seen one.
just so i understand you will then have two feeds going into the cooler? (ie the stock one, plus the feed from the rear pump?).
Nope, when you remove the HICAS the standard input to the cooler goes with it. That's why you have to reroute the input to the cooler.
The output from the cooler always goes back into the power steering fluid reservoir, so no change there.
or you could do what i did and pull the back of the pump off (4 bolts) and slide out the little vane thing inside the pump. and put the cover back on. and block off the inlet on the resouvoiur and the outlet on the pump.  Then remove ALL of the pipiing associated with the hicas.
But then you have no power steering cooler, which may be OK for some, but not for others.
:P cheers :)
Edited by Sydneykid
ahh, thanks Gary, that cleared things up for me greatly :P
Gary with your system you must run a cooler is this correct?? On the 3 or so GTRs i intitially removed the hicas from I was simply blocking up the rear chamber, and the pumps would die I think due to over heating so I simply make sure I do a 2ws pump conversion at the same time, obviously its not needed if you run the pump the way you suggest!! Plus the 4ws pump is a mammout compared to the r33 pumps running a 2ws pumps looks better in the engine bay I think!!!
so does the powersteering really get so hot you need a cooler??
why didnt the orignally have a cooler on the ps?
steve
R32GTR's and R32GTST's have a cooler on the power steering standard. It is a simple loop of aluminium pipe, but it works. On the race R32GTST I have used a standard Stagea auto transmission cooler as the power steering cooler. Works a little better.
:mellow: cheers :(
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
