here is a couple of pics that you can sort out to show us how to do the HICAS removal is done/fitted,
cheers garry.
-pete
(p.s sorry for the 2mb of pics (for the people on dial-up) i'm drunk and cbf shrinkin the pics, l8r.)
From yet ANOTHER HICAS thread.................
I have marked up the HICAS schematic;
The Blue dot is the power steering cooler
The Red dots should be joined together, this bypasses the HICAS solenoids completely.
No cutting of pipes required, around those locations you will find the steel pipework has clamped rubber hose sections, just remove the (short) hoses and substitute them with the new (longer) piece of joining hose. If you are not removing the rest of the HICAs system, then block off the (no longer used) hoses to keep the crap out. There will be power steeing fluid trapped in the hoses, so make sure the capping is liquid proof.
:( cheers :D
OK.....
i have a picture of the HICAS solenoid i hope the picture can make sense for me and all the other HICAS frenzie removalist out there..
after you join them you can freely remove the whole HICAS system?? (aslong as you have a lock bar of course)
what do you think Sydneykid?
OK.....
Join the hoses you marked in red and the rear stage of the pump will just feed throught the cooler.
The rest of the hicas system can be removed.
If you remove the ECU the dash light will stay off too.
It wont be high pressure after you remove the hicas solenoid though, just more flow.
sweet thanxs champ,
where will i find the HICAS ECU?
If you remove the HICAS ECU, do you lose the speed sensitive power steering? Cause when the speed sensor wire to my HICAS ECU was cut my steering was in heavy mode all the time.
HICAS ECU is under the parcel shelf in the boot. Steering at very low speed was heavy with the lock bar installed and the ECU still connected. Remove ECU and steering still heavy at < 20kmh but dash light goes out.
As noted in the many pages of my tutorial, extra castor will make the low speed heaviness almost impossible to detect and improve turn in response.
Hmmm so...even with fitment of the lock bars and the HICAS Pump hoses re-rooted etc everyone who does this mod still has the heavy steering all the time ?
I had an 'off' at a racetrack a few months back, since then my HICAS light has been on and steering has gone heavy 24/7. I would really like to get rid of the heavy steering and thought the Lock bar etc would be the go, but not if it dont fix the heavy steering :woot: ......
Who said all the time? See my post. Steering is only heavy(er) < 20kmh. All other times its no different. Event with it heavy(er), I dont care as it only marginally heavier anyway.
If you have heavy steering 24/7, best be getting that checked out, cant see a lock bar and re-route fixing anything there.
  • 3 weeks later...
ok one more time for the dummies, i'm guessing those pics were from a gts-t
basically for a 32 gtr, if you connect the high pressure hose join points directly under the sway bar on the drivers side with low pressure hose all will be good, also joining the new hose to the in and out points of where the steering rack used to be is good also
just making sure
just making sure
They are from a R32 RB20DET GTS-4, But i have been informed that the GTS-t, GTS-4 & GTR have all the same HICAS setup :D.
R33, R34 Are diffrent because they are electronic. :P
Edited by meep
Not all R32 hydraulic systems are the same.
GTS-T has a shared resivour system. GTS-4 and GTR have a remote resovior system.
Please delete this post, its is WRONG and people will read it and believe it.
The power steering (inc HICAS) reservoir is in the engine bay, on the LHS inner guard just behind the airbox.
The ATTESA reservoir is located in the boot, in the RHS inner guard.
They are in no way joined, shared or common. R32GTST, R32GTS4 and R32GTR power steering systems (inc HICAS) are the same.
:P cheers :D
Edited by Sydneykid
OK guys people are asking about the heavy stearing when the hicus and hicus ec is removed.
Does anyone know what causes the steering to be heavier etc?
Wouldn't this be as simple as finding the corect wire (hicus ecu loom) and roughting it to 12v or ground or what ever it requires to run the steering lighter?
Surely this prob can be rectified?
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
