  • 3 weeks later...
i finally took my hicas out last weekend, took all the hosing, and units out and plumbed the hose back to the breater hose in the front where the 4ws actuator was, works like a dream, just have to take the hicas bulb out of the dash now...
I'm pretty keen to do this, just one question though. Is it better to lock the back up with a lock bar, or with the washers (in weight saving, and strength). I'm guessing that the washers will be fine, just wanted to double check though.
I found a HICAS ECU pinout, and wire 20 is the warning lamp, so if you cut that, it should save pulling the dash out.
Edited by sav man
  • 3 weeks later...
Any chance you could share that pinout?
I really wouldn't mind having a good look at that.
OK.....
i have a picture of the HICAS solenoid i hope the picture can make sense for me and all the other HICAS frenzie removalist out there..
http://image-cache.skylinesaustralia.com/f...-1140862108.jpg
Join the hoses you marked in red and the rear stage of the pump will just feed throught the cooler.
I am confused. My lines have small hose for hose #1 , and large hose for hose #2 ....how are you supposed to join them with a simple 150mm long hose? I must have the wrong line, but I have followed the directions right as far as I know? It looks to me that #2 is high pressure...there is no-where to attach a normal rubber hose without making a fitting ?
If it is the right one, I have no idea how I am supposed to get the hose off there with the metal clamps.
The top of my engine bay looks like the picture posted by meep.
Picture1 - http://image-cache.skylinesaustralia.com/f...-1140862108.jpg
The underside looks like this
Picture 2
http://home.kooee.com.au/exup250/hicas.jpg
I could disconnet it under the car, then run a longer hose up, and use a fitting at the bottom...but this doesn't seem right based on what SydneyKid is saying?
I am worried I am about to rip out the wrong hose. either that or the wrong place, cause i can't see it being a 10 minute job like SK made said
Is the line in red the right place to put the link?
Picture 3
http://home.kooee.com.au/exup250/hicas1.jpg
Edited by eXc
Picture 2
Picture 3
Let’s get the terminology right first then move onto what to do.;
1. High pressure hoses DO NOT HAVE CLAMPS, they have compression fittings. So any hose with a compression fitting on it is NOT low pressure.
2. Low pressure hoses HAVE CLAMPS.
3. What you are doing is joining 2 low pressure pieces of (standard) pipework with a piece of (aftermarket) rubber hose that has a clamp at each end to hold the (aftermarket) hose onto the (standard) pipework.
4. The fluid supply and return to the power steering cooler is LOW PRESSURE, so it has clamps.
5. Follow the power steering cooler (standard) pipework and (standard) hoses and note where the (standard) pipework joins to the (standard) rubber hoses. Note that there is both a supply from and a return to the power steering cooler, the return is LOW PRESSURE.
6. Go to the power steering reservoir and follow the (standard) pipework for the return of the fluid from the rear solenoids. The standard pipework goes under the engine, clipped to the subframe.
7. Join the output of the power steering cooler (standard) pipework to the (standard) pipework where it pokes up from the subframe. It needs around 100 to 150 mm piece of aftermarket rubber hose and 2 clamps.
Sorry I can not put up a picture, so please don’t ask.. My own R32GTS does not have the pipework in it at the moment as I am changing to a larger power steering cooler.
Hopefully that is of some help.
:thumbsup: Cheers :wave:
Edited by Sydneykid
  • 1 month later...
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
