What would happen if one removed the rear steering rack with the lines that run into the "junction box" (I've got no idea what to call it!) and simply put 2 bolts into the holes that the lines came out of?
The power steering pump rear rotor would fail
:) cheers :w00t:
Alright guys i took some pics just before (meant to post earlier but got stuck into wiring up the new battery feed >_<)
The hose i got was heater hose as it needs to be oil resistant. And yes i do know there aren't any clamps on the new hose yet, i still have to get them :D
Hope that makes things alot clearer. If you want any more pics, let me know
Hmm...
I recently had the rear steering rack removed and one of Geoff's HICAS lock bars fitted. Where the two hoses were removed along with the rear rack, bolts were inserted to plug the open threaded fittings. I assume from your post Gary that this isn't the correct way to perform the job and will need a hose that runs between these two points in order to keep the fluid flowing?
ok, i have compltely removed everything that looks like or even smells like hicas on my car....First remove rear rack replace with the lockbar...rip out every power steering line that goes to the back of the car and just follow them where they go into the valve system near the plenum...you can completely remove the valve system no worries....remove the pipes that is meant to be a cooler. remove the hicas resoviour, buy a r31 steering pump a a 3 slat belt to suit. you will need a spacer to space the pump away from the block a bit to clear the cam cover....i used a s14/r33 power steering resoviour, all the pipes hook up nicely to the pump from resoviour and steering rack....ok now under the rear parcel shelf there is a silver box that is the hicas ecu...you can unplug that....Now once you have hooked up the new basic power steering system with the r31 pump and new resoviour....you will notice you have very jolty steering and it will be hard to turn the wheel backward and foward quickly and it will feel like shit.....this is wher some people dont know about...BUT if you look on the actual steering rack iteself you will notice that there is a electronic valve on it on the drivers side with 2 wires coming from it....unplgu it and unbolt this solenoid...Watch out cos fluid will piss outta the rack....then you will see 2 holes in the rack that the fliud comes out of what u need to do now is get some steel or alluminium sheet metal only need enough to cover those holes...so cut out a peice and drill 3 holes to bolt the plate to seal these holes.......once sealed you will have very very light steering...make sure you fill the resovoiur up full when you start the car and then watch the fluid or else the steering pump will sound like its scrapping things...and top up as nessecary. NOW what that little solenoid on the steering rack does is bypass the fluid from the rack back to the resovoiur so that you dont get much fluid in the rack creating hard steering....once its covered the fluid stays in the rack causing very light steering....
Anymore questions about it just pm as i have done it all myself.......also i weighed up the sutff that is removed and subtracted the new stuff put in to make this work and it works out to be a 21.5kg loss of weight......so really youll go faster and use less fuel :dry:
What a timely thread discovery! I just pulled all my hicas stuff out of my cefiro as the previous Jap owner had put a lock bar in. He only put nuts on the ends of both hydrolic lines that use to go into the rear Hicas rack - meaning there would be an obvious build up of pressure at the rear end of the car as the fluid couldnt go in a cycle. Let it be said that nearly every seal in my main steering rack must be fked, as i go thru more power steering fluid than I do petrol.
Im currently replacing my steering rack with a s13 or s15 rack, and I will most likely put a tranny oil cooler in and run the rear part of the pump to that.
Im yet to comprehend what sort of piping and fittings i'll need to do this from reading above - but if someone can assit me that would be great.
My idea is to have the rear output of the pump go to the cooler - using about 1m of hose, then from the cooler back to the HICAS resovior. But will this still have too much pressure going back into the resv? I dont want an explosion of fluid everywhere if I can help it!
thanks!
JK
Edited by jaik
i just thought i'd get someone to clarify this before i start hacking away on my power steering lines.
on a r32 gtst, looking at the hicas solenoid in the drivers side of the engine bay...
Line 1 goes from oil cooler to hicas solenoid.
Line 2 comes from bottom of engine bay into the hicas solenoid.
What is the best way to make the connection to line 2? there are no rubber hose sections that I can find, they are all metal screw fittings. Do I unscrew one of the fittings and just hacksaw the screw bit off? What's the best way to approach this?
From what I understood of what sydneykid posted, you can just hoseclamp the rubber hose onto both line 1 and line2, but i can't find where on line 2 that this can be done without hacksawing off one of the screw fittings.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
