  • 10 months later...
Yeah, I was gonna say something about that :)
Cheers for the pics though, should make the guide a bit easier to follow, my photos are shockin. I'll put all the photos back in order too...
Just my 2 c insteed of cutting the pipe head down to enzed and get a barbed fitting for it so its all nice and neat and wont blow off
  • 7 months later...
  • 5 months later...
ok after reading all 10 pages i just want to make sure of something...
i will be fitting a hicas lock bar to my r32 gtr, do i join the 2 lines back there to each other so the fluid can still 'flow' ?
will this work fine? wont put strain on the power steering pump ?
just wana do this the quickest and best way possible,
thanks !
When I orginally removed my HICAS, I just looped the lines back into each other at the back of the car.
When I removed the lines and solenoid, I just looped it back into the itself under the resevoir.
I will now be utilising those looped lines to install a cooler :)
  • 1 year later...
Great Thread!
Just 1 Question - On the GTR R32,
When you get to the stage where you remove the Red Circled pipe in the Pic below and blank it off on the Power Steering pump,
BUT
Where does the Loose pipe go to, that you have taken off ??
Thanks!!!
It goes to the HICAS solenoid. I have just finished pulling all that out of my R32. There is absolutely no looping involved when you pull it all out. The front outlet of the power steer pump still just goes to and from the rack, and the rear outlet of the power steer pump doesn't exist, because you replace the old R32 pump with a newer one and get a new line made up. All the rear steer plumbing goes in the bin.
So you removed the section with the fluid cooler on the drivrs side as well . . . ? (where most loop the 2 pipes together)
All gone. My "cooler" has been out of circuit for years anyway because it had a crimp in it, was causing high pressure and leakage in the power steering circuit. So my car had been looped out there for a decade already. But now it's all gone. I plumbed a spare little auto trans cooler into the new power steering circuit to provide more cooling than it will ever need (trying to compensate for the previous years of neglect!)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
