i've done a search trying to get info on putting a r33 gtr engine into an r32 gtr. Found this on the difference between them performance wise
http://www.skylinesaustralia.com/forums/in...topic=92904&hl=
in it found this info - r33 has pull clutch unlike th r32 which is push.
my mate is putting a r33 gtr engine in his r32 and is under the impression that it will bolt straight up to everything. Keeping in mind using r33 ecu, loom and turbos. (using r32 gearbox, clutch + so on)
im not so sure.
can people please list some threads or problems that he might run into. thankyou
if clutches are different then this will cause a big problem? yes/no
https://www.sau.com.au/forums/topic/93185-r33-rb26-in-r32-gtr/
yeah the engine will bolt directly up. the r32 gtr ecu should also run it.
r33 ecu and loom is WAYYYYY differant to the r32 gtr one. e.g the r33 have the battery in the boot!
just bolt in the r33 rb26 and use the r32 gtr ecu and loom.
cool, that'll save him some cash. umm, what bout clutches, pull/push. doesn't matter or is that incorrect?????????
it will all go in.
hel need to use the 32 clutch and flywheel.
also the 32  02 sensors. diferant. it will have drivability problems.
Drivability problems???
Why is that???
Aren't these engines very similar???
this is happening and if we are going to run into major problems then he'll be probably be better off getting a 32gtr engine.
i'm guessing someone must have done this before, can you please put in your two cents.
i'm sorry if this has been discussed at length before but i can't find anything. thankyou
32 02 senors are a "titanium" type. they work completly diferantly.much like a proper a/f sensor but not as advanced.
they vary a voltage going through them acording to the a/f ratio. rather than put out a ocilating voltage. i think.
33 ones are the normal type whatever that is.
besides i used a 33 computer on mine 89gtr(a/c testing etc) and full throttle is fine but light throttle was so bad i thought i had a dud afm!!
basicly any throtthe opening where closed loop control is used {everthing except full throttle}
it will buck and carry on and give him the shits.
wont notice it till they are up to temp.
i first ran in to this when i thought id use a 33 computer to get the better programing.(more torque)
hope that clears t up.
hey guys, i'm the mate who is getting the engine put in. Just signed up to the forum today. thanks for all the information, youv'e convinced me it's worth being a member. Hope to catch up with ya all if/when the car is back on the road. thanks again, will keep ya's posted with the progress.
here's some pics of my baby, not much to look at yet but give me time :P:):O
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
