Can some one please show me some pics of how to install an intercool into an r32 gtst, i think i have it all worked out on the right hand side (looking at the car) but on the left i cant work out how the pipes come through. Also how much of the stuff needs to be removed in the front bar for them to work?
I have done a search and it was not very helpful.
BTW. Intercooler is a Autotecnica cool 8 kit.
https://www.sau.com.au/forums/topic/93202-intercooler-installation/
Assuming you are looking at the front of the car(RH Drive) - drivers side a hole needs to be cut in the body, passenger side it runs up thru the standard piping. This is assuming your kit is an up and over the radiator type. Cutting the hole is simple as there is a hole marked for if the chassis if it is used for a GTR - at least thats where I ran mine through..
Depending on what frontbar you have determines how much choppy you have to do...
Have a look at where your battery is - it is sitting on a right angle sort of shelf - the hole will be made in the side of this shelf below the battery so you don't have to relocate it... keep in mind I am only assuming this is how your kit goes as pretty much all of the kits I have seen that don't return through the factory piping on the same side go this way..
I am working on the pics - actually I will make a rough one in paint so you get the idea.
i installed my intercooler kit on the weekend, you have to holesaw a 3 inch hole under your battery tray. i have a standard type m front bar and i had to chop it out pretty hardcore to suit the cooler and the piping. i will put up some pics of the cooler and how it looks with the chopped front bar. joe
i see now, silly me. Ok then next question. Where does the intercooler bolt into? Im having trouble working out where it goes and how much of the front bar will need to be attacked lol
Also how long does it take to install. It seems fairly easy (touch wood). Done in an afternoon?
Yeh I did mine in an afternoon/night... you will probably need to bolt your intercooler to your bumper support bar - which will also probably need some choppy chop - BUT this all depends on your kit, I am basing these instructions on installing a china copy kit, It wasn't too hard in the end but did involve a fair amount of swearing.. yours could be different..
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
