A long front bench with steel table top and tool wall.Or a lrge roller tool chest.
Compressor,and,wind up hose on the wall .Welder/oxy.
Sheet metal bender.
Lock up cabinets dynabolted to the floor.
Head room for roof storage.
Nuts,bolts,rivets,clamps,electrical connectors ra ra ra,all in slide trays under the first level of the bench.
Pit.
Fire extinguisher.
The garage:Small Sink,bar,Fridge and tap (no not beer tap) Sigh i hear him say.And a drainage mote' arround the garage
Most of all you need room to swing so the bigger the better.
Edited by Trust33
  • Replies 46
Posted Images
Restating what everyone has said, but at the very least, make sure your floor is painted a lightish colour with some kind of protectant so its easy to clean up spills, and generally easy to keep clean/sweep plus if you drop some small part its easy to find on a clean floor.
Also at the very least ensure you have enough space to pop the bonnet. In mine, the roller door machine gets in the way, so make sure you have that covered.
Good ventilation is a good idea. Don't want to loose a brother cos he couldnt breathe!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
