I just fitted an A/R Ratio gauge and it's showed me something thats concerned me a bit..
On idle or if I'm driving then release the throttle completely it runs all the way towards Lean and then off the LED dial thingo.. Does it mean that it's running that lean??
Cos thats surely not a good thing right?
I just had a PFC fitted and tuned and when the car is hot it makes a funny noise out the exhaust on idle - it's not like a clean idle it sorted makes a popping sound or gargle.
https://www.sau.com.au/forums/topic/93226-af-ratios/
It is very normal to run lean on a trailing throttle. You only need to run nice and rich at full throttle, in normal driving the O2 sensor is designed to run the ECU at around 14.1
And assuming you have a AFR gauge running off the standard O2 meter, they aren't much use :D The gauge is only accurate around 14.1, it can't accurately measure 10 v 11 v 12 etc etc
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682033
I would tend to trust the tuner, but.....
My Apexi turbo timer shows A/F ratios while running, and shows lean as when you back off going down a hill for instance. I beleive that this is nothing to worry about at all.
Your guage showing lean on idle is something that I am not familiar with as mine shows mid 14's on idle.
All the best.
El Bee
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682059
yeh remember that a normal o2 sensor only reads a 1 volt spectrum of accuracy... i wouldn't pay much attention to it
we had a mates old soarer on the dyno a few weeks back which was doing weird stuff according to an autometer a/f guage, and yeh found it to be perfectly normal to go lean on decelleration and idle (mind you on the high side of lean)...
read Sydneykids article on the Tech Edge wide band A/F thingo
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682109
^^ Yeah I know that, but (as I only realised the other day), you are supposed to enter the A/F and O2 sensor parameters on the Auto Timer so it can properly estimate the A/F..otherwise you'll end up like mine where it constantly flashes '---'
eg A/F can be 'set' between 10-and 20
and the 02 sensor voltage between 960 and 002
Would you mind taking a look on yours and telling me what it's set to?
//edit: all I need is for you to is
1. While A/F selected, hold the knob to the right and tell me what it's set to
2. Hold knob to the left to cancel adjustment
3. Move down to display O2 sensor voltage, hold knob to right and get the setting for me.
4. Hold knob to the left to cancel adjustment
It's straight from the AutoTimer instructions.. I'm just not sure what they should be set to on skylines..
Thanks! :)
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682323
on decel - i.e as soon as you take your foot off accelerator fuel is cut. i.e no injectors are pulsed
Therefore 02 sensor voltage = 0 i.e. completely lean - i.e. there is no problem.
Cars use this to pass emissions and increase fuel efficiency
Edited by benl1981
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682359
Waste of time and money, disconnect it and move on with your life.
:) cheers :)
PS; obviously this doesn't apply to fast and wide lambda sensors and properly calibrated A/F ratio meters.
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682381
Have seen them play havoc as well with standard computers ie poor grounding/wiring leading to wrong voltage bias on narrow band O2 sensors. Its always cool when the standard computer is trying to trim the wrong amount of fuel in or out.
We use this ability of altering the 02 sensor bias with our Xede processor to enable a lean cruise function(with the right conditions of course).
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682465
we.....our.......Xede :)
Oh goody, someone who knows about Xede's.
I feel a new thread coming on.
:) cheers :)
https://www.sau.com.au/forums/topic/93226-af-ratios/#findComment-1682690
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
