Guest Pearman
Hi,
I have been told that during winter months, salt is used to breakdown ice on japan’s roads. I’m also told that this leads to higher levels of rust in jap cars.
Questions,
What do you guys think? Found much rust in your cars?
If so, where are the problem areas / common places to checkout?
I also here that AM body kits are sometimes used to hide rust, etc
Any comments…
Thanks
Pearman
https://www.sau.com.au/forums/topic/9324-rust/
It doesnt snow that much in Japan. The mainland and the south in particular (where the most people live) is more prone to temperate/sub tropical climate which has typhoons and torrential rain in winter, humid wet summers.
Sapporo however is usually covered in snow during winter, but thats about 1.7 million people out of 126 million. Not that many cars really :P
I dare say the problem exsists, but its probably fairly uncommon. If your worried, id check things like chassis rails and subframe parts.
Red17
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140159
Yeah just have a good look under the the car... ie subframe etc...
I checked out mine before i bought it and was really impressed with the condition of the car in terms of rust, mainly because i found absolutely none... japan would be alot less harsh in terms of rust than us here on the east coast of australia i think?
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140171
Sapporo however is usually covered in snow during winter, but thats about 1.7 million people out of 126 million. Not that many cars really :)
It sounds like you know alot about Japan, but I'm confused. Have you ever been to Japan?
I just came back from two weeks in Japan where I was based in Tokyo and backpacked around north and south of the main island. I caught the Shinkansen to Hiroshima, Kyoto and Nagano.
It was snowing all the way to Hiroshima (Kyoto is on the way), it snowed in Nagano (obviously), and even snowed in Tokyo the day after I left.
From my brief experience and most importantly talking to people who live there and/or have family there, it seems that Japan sees a LOT of snow in their winter.
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140201
Ok maybe im wrong then, damn university education lets me down again. These authors of text books should really stop publishing lies
Red17
BA (Geography)
hehe...
Makes sense, my degree was full of outdated procedures and programming languages... Silly University :)
In any case, as I said, I was only there for two weeks, so I'm hardly an authority on Japan, but the impression that I got was that they get their fair share of the white stuff ;)
https://www.sau.com.au/forums/topic/9324-rust/#findComment-140227
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
