Left overs from R32 half cut. Located on southside of Brisbane.
Standard dump pipe $30
Standard front pipe $30
R32 turbo good condition but been sitting for a while (minimal end float) $250
R32 aircon condensor VGC no bent fins $80
Power steering pump and reservoir $80
R31 starter motor $50
R32 overflow bottle (no cracks) $10
R32 wiper bottle (no cracks) $10
RB20det std injectors X 6 GC $150
RB20det auto wiring loom $100
RB20det motor. Guaranteed runner, NO smoke. Has gudgeon pin knock due to shit timing tuning on microtech. Just motor and head. $200
RB20det inlet plenum $50
RB20det alternators X 2 $50 each
RB20det coil packs X 6 $100
Sorry bout the crappy pics, can take better ones if you PM me. :D
Regards
Steve
0411 206 780
Edited by RB180sx
https://www.sau.com.au/forums/topic/93241-r32-bits/
Hey, Was just wondering if you had an orange SIDE indicator cover(small round one) for an R32?
I lost one of mine somehow :S
Nath
Sorry Nath, just got the bits I mentioned. Half cut is gone! Should have pulled more off it B4 it went!! :)
Regards
Steve
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1682454
Do you know if the PwrSteer Pump/reservoir is HICAS version or not? Have a clearer picture or part number of it?
Where abouts on South Side are you, I am at Underwood so could drop over to check what is left as I am after a few things.
Thanks
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1699695
Yes it is mate. Its for an auto if that makes any difference.
Im in Hillcrest, near Browns Plains
Regards
Steve 0411 206 780
Hey mate,
Is that wiring loom, a complete engine wiring loom?
Where abouts are u located on the southside?
Cheers..
https://www.sau.com.au/forums/topic/93241-r32-bits/#findComment-1725767
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
