Hey,
Is it normal practise for a tuner to melt your hi flow cat, then when it doesnt flow, to punch if out so its no longer a cat?
Obviously if the high flow cat melted, it wasn't much of a high flow.
:) cheers :)
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1682699
Hey,
If the tuner punched out the cat, then I suggest you get him to replace it (or maybe punch him out!).
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1683638
Thats dodgy pratice for a mechanic to be doing that sort of thing. He could be up for massive fines, and more likely to be on the receiving end of the fine than joe public.
Cat shouldn't melt.. must have some massive heat (...more so than standard) coming down your exhaust, which could be a cause for alarm
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1683924
People DO get fines for this. I know of a $3200 fine. happend to someone i know at small car sunday one year. The police were there inspecting cars. All they were checking was ride height and exhausts. they let everyone off with a warning except for those with environmental issues.
I think there were 3 cars fined in total and one was for no catalytic converter.
BE WARNED!!!!
There is a guy on these forums called BATMBL and he sells very good quality cats for a good price.
Check to see if your O2 sensor is connected. and if so you shouldnt be melting cats. I would have the AFRs checked if a hack has tuned it. Take it to somewhere reputable and for $50 they should do a power run to check AFRs.
goodluck and replace that cat ASAP :P
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1683980
it is not uncommon for your cat to melt if your tuner likes to tune your car to be a bit on the safe side
this is like 11:1 under power or richer with a not so agressive ignition curve
this is good because it stops you popping your engine but it also causes a bit more heat and unburnt fuel which is what kills your cat
the only time iv ever heard of people getting fines for not having a cat is when they replace it with a straight pipe
if it looks like its there than what are they going to do....take it off on the side of the road to prove you havnt punched it
id like to see that
the only way they could catch you is if they do an emissions test and even if you fail that and they discover you have a puched cat,your not a mechanic and you didnt know that you didnt have a working cat
you will be right dont let these guys scare you
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1684254
i thought tuners liked to take out fuel and add ignition over stock settings to increase power, given that stock ecus run rich and retarded. if not, my stocker should've turned the cat into a molten lump by now?
Edited by GTR32
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1685396
the rich/retard safety feature on the standard ecu is much richer than 11:1
and im not saying it will melt the cat down straight away, it could take week or months
its just one of those things
depends how old and what quality your cat is
excess heat and fuel will kill a cat in the end
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1687555
Isnt more heat produced when your car is running lean?
If the mechanic wrecked ur cat and then removed it, i would be asking for it to be replaced free of charge. Especially if they didnt ask you first.
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1688402
Running richer results in more unburnt fuel.
This fuel travels out of the turbo, down the pipe and collects in the cat.
Cat get really hot and this temperature causes the fuel to ignite inside the cat. This furthur increases the temperature causing a positive feedback mechanism inside the cat...
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1688473
Modern ecu's have cat overtemp protection on them which means once they exceed a preset value the mixtures are richened as in really rich a standard GENIII will command between 11.0-11.2 for cat overtemp. There fore a leaner mixture will kill your cat quicker then a richer mixture. The thing to watch is how retarded the timing is.
Thing is shit happens, get over it and move on. Yes he should have told you before bashing it out. He really should have just removed it and run the car to make sure the cat had broken up. Anyways when your modify your car you should expect some small things to go wrong.
https://www.sau.com.au/forums/topic/93264-melted-cat/#findComment-1688601
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
