I have always wondered why Xedes are not more popular for use on Skylines. Theer technical specs look impressive. They pop up on every other Foulcan Tubbo, but I can't say as I have everr seen one on a Skyline.
Does anyone have any idea why this may be the case?
Is it simply lack of promotion to Skyline owners?
Or is there some technical deficiency?
Maybe the price?
:) cheers :)
https://www.sau.com.au/forums/topic/93266-xede-for-skylines/
The Xede is a really nice peice of hardware and can bend any input you can throw at it. it would be a really nice product if it was around $500.
But the reason i dont think it is so popular is for the $900 odd pricetag, a PFC, wolf V4 or a number of ECU's can nearly be had.
I have seen one on an XR6T controlling ignition, fuel map and a methanol spray kit. they are a great product but for skylines they are entering a saturated market.
:P
:P
I thought that $cost may be the problem, but I see EManages on Skylines and they cost similar to the Xede. Is it because it isn't Japanese?
:( cheers :D
I think that has something to do with it.
Also as you said, its all about education. Seeming as most skyliners prefer jap performance, they will buy jap products. Better the devil you know sort of logic.
I am sure with some more exposure the Xede will find it's way into many skylines, especially when the price goes down.
We are having problems with the nissan crank angle sensor. But I think also that the market for the xede on skylines just wasn't there. However I have been talking to my boss the technical director of the xede and he said if it can generate enough interest with the nissans then he would go ahead and develop it. What do you guys reckon?
The 350z is a 36 minus 1 I think. We started with the 6-5-4-3-2-1 CAS signal and never followed it up. If there is enough interest, who knows. The xede doesn't drive the coils directly like the emanage. However I heard of several damaged coils in skylines with emanage.
The xede is a very proficient boost controller. With the fords we use the output of two maps to determine what wastegate DC is. For example a Wastegate DC vs Map vs RPM and a Wastegate DC vs TPS vs RPM. Its semi closed loop boost control. The xede also has a switch that can change entire maps on the fly. The list just goes on and on.
rob82
keep the info coming the more info the better
us consumers need a range to select from from the most basic to the most advanced
the more we have to choose from the harder the aftermarket tries to compete
therefor the consumer is offered a better priced better functioning unit
we have to select from
my 2 bob anyway
It is a piggyback unit.  http://www.xede.com.au/  Its alot more functional as you can choose the map axis and also use multiple map for complex functions.  If you want more info just let me know and I'll get the xede training day presentation.
Hi Rob,
Hell yes please, this is too good an offer. can you send to [email protected]
And to answer this question...
As long as it comes with a gun tuner we can proceed.
Kind regards
Edited by GTR32
How about closed loop fueling - as in tuning the car under full load as well as partial throttle. What we do is feed the input of a wideband 02 sensor and alter the MAF signal to get a desired AFR. That means instant tuning as you drive down the road.
My boss is in the states at the moment experimenting with knock sensor tuning as well. You basically feed the knock sensor signal in and trim either side of a detonation event. The biggest thing is being able to clamp the output of the knock snsor on the rev limiter as the occurence of knock at the rev limit is high. It has been found that up 25 to 30 ft.lb more torque on the gear change in an EV08 - which is a shitload.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
