Last night i was commin home when i came around a corner n the second i went to accelerate, my car (R33GTS-T) lost all power n rolled to a stop. the lights and radio all still work.
When i tried to crank the car back over the thing just sounds like a spinning noise and it wont start
Its not fuel because i can hear it. im lost, my baby wont start...
any help would be appreciated
https://www.sau.com.au/forums/topic/93275-skyline-wont-start/
Put your hand over the air intake and have a buddy turn the engine over. If you get a push - pull air flow (air sucked in, then pushed back out) then I've got some bad news for you. . . . Timing Belt.
My heart sinks for you at just the thought, but it's the easiest thing to check for.
Edited by RB240Dav
if its the timing belt, i dont care, but if its bent the valves, ill die
ive got an idea that it could be the crank angle sensor..
also i've been told from a few ppl its could be coil packs (?) to do with my remote start n alarm etc that is lose n its activated my engine disengage n thats why it wont start ...does that sound right?
the belt had only 51,000 ks on it, thats whats pissed me off the most.
The guy who has to rebuild it says, maybe coz its the original belt and the the car is 10yrs old (1996 model) it happend with age.
this aint my day
Timing belts should be changed every 100 k k's or 5 years wichever comes first , thats what most car makers recomend . They will usualy last a lot longer but you cant take the risk. In wrx's they should be changed every 4 years and some diesel landcruisers every 150k k's or 7.5 years but they have a short and thick belt .
10 years out of a belt you are asking for trouble , just look at your driving belts ( air cond, alt+ power steer ) if they are 10 years old you will see tiny cracks on them .
nah the importer confirmed my timing belt snapped. so im gettin a rebuild, i've already organised it n the car has been towed upto dandenong for it (over an hour from my place)
the car is under warranty still, so im only outta pocket for the tow truck there and back
Lucky mate. Very lucky about the warranty.
The first thing anyone who imports a car should do is change the timing belt. As we all know, most cars are wound back so even though your car might say 50,000km for all you know it could have done 150,000km and be well due for a timing belt change.
It's really not worth the risk.
well when my car came into australia 2 months ago they changed all filters and everthing else, but the timing belt was never mentioned.
bt3tt, mate ur so right, lucky the warranty covers it all. Warning to anyone who gets an import, change the timing belt, because you dont know how many k's the cars done. Also i was told that it also is cause because the car has the factory timing belt and being 9yrs old it gave way
That just sucks, but it's a good reminder for blokes like me who have just got a car recently imported car. I wonder how much the importer will be up for....
What places will sell a timing belt for RB20? Easy to check condition of belt? Take cover off?
I'd be relieved to a degree that it happened when under warranty
Edited by GTAHH
A timing belt stretches out over time through wear and could break at the worst possible moment, like what happened to Mr_crust. As it stretches, the engine slowly goes out of time resulting in decreased engine performance, lower petrol milage etc.
If the timing belt breaks, the camshaft will stop turning in time with the engine while the crankshaft continues to turn for a short time until the engine dies.
In that short period of time major engine damage could occur such as, broken valve guides, bent valves or a broken camshaft = bad.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
