Last night i was commin home when i came around a corner n the second i went to accelerate, my car (R33GTS-T) lost all power n rolled to a stop. the lights and radio all still work.
When i tried to crank the car back over the thing just sounds like a spinning noise and it wont start
Its not fuel because i can hear it. im lost, my baby wont start...
any help would be appreciated
https://www.sau.com.au/forums/topic/93275-skyline-wont-start/
Put your hand over the air intake and have a buddy turn the engine over. If you get a push - pull air flow (air sucked in, then pushed back out) then I've got some bad news for you. . . . Timing Belt.
My heart sinks for you at just the thought, but it's the easiest thing to check for.
Edited by RB240Dav
if its the timing belt, i dont care, but if its bent the valves, ill die
ive got an idea that it could be the crank angle sensor..
also i've been told from a few ppl its could be coil packs (?) to do with my remote start n alarm etc that is lose n its activated my engine disengage n thats why it wont start ...does that sound right?
the belt had only 51,000 ks on it, thats whats pissed me off the most.
The guy who has to rebuild it says, maybe coz its the original belt and the the car is 10yrs old (1996 model) it happend with age.
this aint my day
Timing belts should be changed every 100 k k's or 5 years wichever comes first , thats what most car makers recomend . They will usualy last a lot longer but you cant take the risk. In wrx's they should be changed every 4 years and some diesel landcruisers every 150k k's or 7.5 years but they have a short and thick belt .
10 years out of a belt you are asking for trouble , just look at your driving belts ( air cond, alt+ power steer ) if they are 10 years old you will see tiny cracks on them .
nah the importer confirmed my timing belt snapped. so im gettin a rebuild, i've already organised it n the car has been towed upto dandenong for it (over an hour from my place)
the car is under warranty still, so im only outta pocket for the tow truck there and back
Lucky mate. Very lucky about the warranty.
The first thing anyone who imports a car should do is change the timing belt. As we all know, most cars are wound back so even though your car might say 50,000km for all you know it could have done 150,000km and be well due for a timing belt change.
It's really not worth the risk.
well when my car came into australia 2 months ago they changed all filters and everthing else, but the timing belt was never mentioned.
bt3tt, mate ur so right, lucky the warranty covers it all. Warning to anyone who gets an import, change the timing belt, because you dont know how many k's the cars done. Also i was told that it also is cause because the car has the factory timing belt and being 9yrs old it gave way
That just sucks, but it's a good reminder for blokes like me who have just got a car recently imported car. I wonder how much the importer will be up for....
What places will sell a timing belt for RB20? Easy to check condition of belt? Take cover off?
I'd be relieved to a degree that it happened when under warranty
Edited by GTAHH
A timing belt stretches out over time through wear and could break at the worst possible moment, like what happened to Mr_crust. As it stretches, the engine slowly goes out of time resulting in decreased engine performance, lower petrol milage etc.
If the timing belt breaks, the camshaft will stop turning in time with the engine while the crankshaft continues to turn for a short time until the engine dies.
In that short period of time major engine damage could occur such as, broken valve guides, bent valves or a broken camshaft = bad.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
