I was checking out greenline.jp and found their comment for the key as below:
"Discontinued. KEY01-RN010. Not suitable for vehicles fitted with Immobilizer, Intelligent Key, Electric Key or Keyless entry."
Does the Nismo key start the R34? My existing key looks to have keyless entry, but I don't use it as I have a separate alarm anyways. I should be able to get the Nismo key cut and itll work fine right?
I searched other threads and everyone seems to think so also.
I got a Nismo key for my R32 from nengun $60 delivered
but it looks like the 10 point key for new nissans is discontinued
Brand    Nismo
Category  Accessories
Nismo 8 Point Key, to suit these Nissan vehicles:
    * Siliva /180 SX S12, S13, S14
    * Skyline GTR R30, R31, R32, ECR33
    * Nissan Z31, Z32
Nismo 10 Point Key, to suit these Nissan vehicles: (Not made anymore)
    * Siliva S15 (This Key Is not made anymore)
    * Skyline R34, V35 (Car be used with the imobilizer)
Please ask if you vehicle is not listed.
so if i buy a nismo key off like nengun, and get it cut to match my R33 key, will it work fine with an aftermarket alarm etc installed or is there some kind of issue? i dont see why the key would make a difference, its just a different key....the alarm is all seperate anyway
i was after another key for my r34,
they told me the blank one wouldnt start it as its need a chip or something in it... they said i would have to order it from japan and quoted me 350 to get it and tune it to car!!!!
""back away, not today""
It will work on the 33 no problem , they don't have the immobiliser chip .
Some 34's do some don't , all 34 gtrs that i have seen have the chip in them .
You can buy the 34 gtr key from Nissan then have it cut to suit your lock but you will have to program it to suit your immobiliser ring , Nissan will charge you $50- 100 to do it .
How can you tell if you have an immobiliser? My key is pretty chunky, but its only got the lock/unlock buttons on it.
Its a 98 model, so I am guessing no immobiliser.
You can tell if your key has a chip in it , they are different . The best way to tell is go to a locksmith and show them your key they will know , some of them can program them as well , much cheaper than Nissan .
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
