hey fellas after owning an r33 gtst after something new, was wondering what the r32 gtst4 all wheel drive skylines are like,
Would like to now realiablitiy of them are like parts and can they take abit of abuse etc, also fuel wise what are they like any info be great guys or are the real wheel drive versions better cheers
https://www.sau.com.au/forums/topic/93304-r32-gtst-4-any-good-or-what/
Expect immediate power loss if they're both stock as not only will you be competing with a smaller engine, you'll also have a heavier (than 32 gts-t) car and the extra loss through the 4WD drivetrain.
If you're planning to mod the car (to a reasonable level) then the lower power can be overcome but if you're leaving them stock I'd either keep the R33 or get the R32 Gts-t as with these levels of power (under 300bhp) the 4WD will only really be an advantage in the wet.
GTS4's are fun, but don't expect it to be anything like a GTR. its supposed to be a GTSt that can be used in snowy areas or places where you don't want the rear wheels to get bogged down in. Spend some money on it and you'll have a fun car, but then again, you can usually spend the same amount of money and buy a GTR to start with.
gts4's are pretty good, I had mine for 6 years before I said good bye.
Just make sure you know what you want to do with the car , i.e. power wise, and upgrading suspension etc. The gts4 uses GTR suspension and just about everything besides the engine/gearbox ratios and dif.
So if you get into upgrade mode you can easily spend the same money someone who has a GTR will with one catch, it won't sell for the price a GTR will, even after you put in all those nice GTR bits. The good thing being that a GTS4 will be cheaper to buy, and a std GTS4 will be pushed very hard to break bits that are designed for a GTR's power output.
Not to knock the car, if you are happy with potential of 200 odd kw($5-$6k- at cheapest) at the wheels with a few mods then go the GTS4. You'll love the wet weather performance and you will go looking for wet roads!
If you think you could go nuts - i.e. you need this bit now that you upgraded that bit syndrome - go the GTR. An otherwise stock GTR running 14/15 psi, k&n, 3.5inch cat back, rechipped ecu will put out about 200kw at wheels.
The GTS4's std are not slower than the GTST's, maybe if you are dragging from the lights in the dry but on a circuit its a different story, I have track times to prove that at QLD raceway. I remember a GTST which was running wider tyres than me and stock like mine and it could not pull away on the straights, although I couldn't run the same cornering lines as him due to my extra weight and narrower tyres. I had to go into the corners a bit softer but I was able to come out of them at full acceleration while the GTSt was just trying to keep it straight and get traction.
No matter which way GTS4 or GTR you will love the traction advantage!
p.s. I am thinking of getting a R34 25GT-Four next year, only 2.5 NA awd, but theres always a front cut from a stagea to make it turbo...
Edited by gts4diehard
man are u serious that 5-6k will get u about 200kw?what mads would this include?im looking for a gts4 as well and am hopefull of getting near to 300rwhp( mads im planning to get to this hp figure:new turbo,fmic,exhaust,fuel pump and injectors,pwr fc,up the boost to about 12psi normal driving and a bit more when drifting)...am i dreaming to get these pwr figures?
to clarify, I mean 200kw at wheels, not at engine, so your rwhp is realistic with those mods.
I think $5 - $6 k on the cheap side really.
microtech $1200~ +$500~ to tune, haven't got any mates where tune would end up less than this, always seems to need more than one attempt to get it right- especially if you like cold start and idle to work properly.
turbo - new $2000~ see horspowerinabox etc
injectors if required - $$900 - new for 6
front mount - cheapie inc pipes $700 - new
exhaust - 3 inch cat back $400 2nd hand
fuel pump $175~
boost controller $
labour costs to fit turbo, exhaust etc..
dump pipe $250
high flow cat $200~
of course all the same costs for a gtst too.
but need to be realistic if you want the HP, i know a few guys who ended up going the mod route and they would have been better off to save and buy a 'Good' GTR.
Stephen
I have a GTS-4 4 door with an RB26 in it (and a few other GTR bits). They can be modded to drive pretty much indentically to GTRs (almost exactly the same drive train) however they do suffer from the small engine and bogging down. I wouldn't want to compare to an R33 though, very different cars.. R32s are a lot older, expect to notice the differences in age very very quickly :D.
i own an r32 gts4 and cant be more happy with it. im glad i went the 4wd over the rwd. though i dont have experience driving a gtst, popping the 4wd fuse is only fun for a few days, after that i put it back in and enjoyed knowing the front would kick in if needed. not saying i thrash the car, though.
as for bogging down, learn to launch and its not so bad. not saying im professional, but i find prerevving to 4000rpm and a hesitant style popping the clutch (not quite dumping, but a smooth dump? heh) will find the wheels chirp and rocket off. wet driving is great also, even my friend with a worked rb20 powered vl thinks the car is great in the wet.
i suppose everyones right though, if youre chasing a cheap gtr by modding the hell out of it, probably better to get the gtr outright. gts4 is good for traction comfort i think.
shaun.
The GTS4 pulls well out of corners obviously and is a lot of fun to drive, it depends what you can do yourself in the modification process. People who get everyone else to do their car up are always going to be paying a lot more (labour, getting ripped off etc). If you are proficient at modifying cars and know people who can get cheaper parts the GTS4 bang for buck will be better in my opinion. The extra traction is a clear bonus and installing a switch to cut the circuit for the fuse to RWD is great fun. Obviously as with GTR's can be understeer, but with correct mods, knowledge and contacts it's a great way to go. Not to mention it's different to most R32 Skylines out there...Thoroughly enjoy mine!
thanks for info guys been great yeah i would be mooding it over time to say roughly 200 plus rwkw its either guna be the gtst4 or an 180 but you think i can find a nice one not likely all are claped out or done to many km 180 that is.
Getting desperate for car after selling the 33 bit toey for something else :lol:
  • 3 months later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
