Hi All,
Just a reminder to all as previous post for some reason got deleted that there will be a dyno day on the 6th of Nov at Power Tune Australia. It will $50 for 3 runs and printout of the the highest power run.
Also a bbq is provided, LCD screen to show each cars readout, and some HKS parts on display.
Hope the skyline crew can be there as a good turn out is expected.
Thanks All
DYNO RESULTS & PICS ARE UP NOW!!!!!
Edited by mac30
https://www.sau.com.au/forums/topic/93311-dyno-day-power-tune-australia/
  • Replies 42
Yep, the www.bom.gov.au site has just been updated.
Sunday : Fine, sunny periods. N/NE winds.
Sydney: 19 25
Liverpool: 15 27
Penrith: 17 27
Richmond: 15 27
different to when I posted earlier. Damn weather!@#!
yea same info needed. heard it was in fairfield somewheR?..:S but yea. would i still b able to join in at 4pm? coz i have work and dont finsh till 3, then gota drive all the way ther from the city...dammit!
I went for a run in the afternoon but my car pinged pretty bad after 200kw so ended up with a max of 207. Was told by the guy there that the manifold is restrictive. I haven't done much research but thought that stock R33 manifold should be good enough for up to 250 kw. Anyway will post this question in forced induction.
Most of the cars there were silvias or gtir. Lots of flutterings going on :P Saw a pretty thrashed looking 180 that made 227 kw, what a sleeper. Had a chat with silver-gtst, nice car dude. Bad luck with the running rich. It seemed all skylines didnt have much luck today. Overall today event is very well organised.
yeh its a shame things cant just go right for a change
ahhwell
hey im new.
it did turn out a good day.
met some new people! bbq was great. an damn man the vtir was off the hook lol.
me an my bro went in the 32 GTR and with the 34, silver DC5R, blue gti-r an corolla gti.
does anyone have any more pictures?
Edited by Alanskii
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
