my GT40 has the oil restrictor built into the cartridge, but it's plain bearing. have you guys heard of plain bearing GT's suffering the same fate you're talking about above? or is it just the ball bearing cores?
also i'm using -6 braided speedflow lines, is there any way your lines can be too big? i'm worried that it will take a while for that volume of space to be filled with oil on start-up that's all. it's high mounted so the oil will probably drain back into the block when the car is turned off :P
hi i have fitted a few different garret turbo's to rb 26 and most of them will need a restrictor , rb 26 engines have one of the most high oil pressures out of everything i have had instances where engines have been making 50 psi oil pressure at idle , this is to much for a ball bearing turbo turbo at idling speeds and will push oil past the seals and cause it to blow blue smoke at idle ,you need to be using between .9 and 1.1 mm restrictor it does not have to be built into the turbo it can be anywhere in the supply line this will drop your idling pressure to around 10 - 14 psi the oil pressure will increase as the engines revs increase , it would pay to put a oil pressure gauge after the restrictor so you can keep an eye on it
An oil restrictor will increase pressure, not drop it!! It sill restric volume, not pressure! If you mean the pressure in the core itself will drop, then yeah it will.
Edited by Mik
Mik,
Remember that the oil from the oil pump has more than one option - it goes into the motor as well as the turbo. Fitting a flow restrictor on the turbo will not change the pressure upstream worth a damn but will reduce the flow and hence pressure downstream - ie in the bearings and around the seals where it counts.
  • 3 weeks later...
Hey there guys, its seems appropriate to re-open this thread now since I have just taken my car down to the Collie track and guess what?
I think I may have pushed oil past the Turbo seals...
Car went great for just a handful of laps then suddenly lost power.. looked in the rear view mirror to see a large cloud of blue smoke.
This morning, there is a small pool of oil leaking from my BOV's...
Motor seems to run alright though, so hopefully no damage done..
What are people's experiences when this has happened? Just clean out all the intercooler and piping? Fit a restrictor to the turbos and she'll be right? Do the turbo's need to be taken off and looked at?
Or is there something darker awaiting me...
--as a side note--
Oh! I should mention this also. When I got my turbos (they are ball bearing) and spun the compressor wheel on them, they didn't spin for more than about a second. I figured they just needed some oil. Once fitted to the car and they had done some dyno work - I would take the car home and switch it off. If I listened very closely, I could ~just~ hear them spinning down.
Since coming back from the track, you can ~easily~ hear them spinning down - they are MUCH louder.. although my mechanic listened to it and said all the noise just appears to be 'suction' at the pods.. Doesn't sound like bearing noise or anything... Do these things "loosen" up? I am a little worried by the 'change' as I would have thought ball-bearings would be free'd up from day one...
--as a side note--
This sounds a little different then the normal oil pressure on turbo seals
The engine would have been up to temp by the time you ran into a problem yes?
Are you running std oil pump?
What turbos are you running?
Are you sure you did have an oil breather problem out of the rocker covers (to much oil to the from head constant high revs with poor draining) as a friend did this recently made a hugh mess in the engine bay and there is a connecting pipe to the intake which could explain the bovs
thats what im thinking myself :(
Hi Pete, yeah I had hoped it was this too. We checked the inside of the pipes from the back rocker cover. They were both 'reasonably dry' although the one on intake side did have a little oil in it.
The thing which made us go to turbo seals was that we popped off the silicon pipe leading off the compressor side of the turbos (the bit that says "twin turbo") and that had oil in it. (quite a bit). So figured this must be it?
Does that sound right?
in answer to your questions though:
Yes the engine was up to temp.
I can only 'assume' the stock internals and oil pump are standard, but can not be sure of what work was done prior (I think its a stock internal job though)
And I am running the 2560r, the -7 though, not the -5 like you.
I didn't fit restrictors because most felt they already had them and Turbotech said I wouldn't need them.. but er.. they might be wrong? :(
how much boost and what condition is the motor?
is it a little tired at all?
hmm.. I don't think I like where that question is heading...
I refuse to answer that on grounds that it sounds expensive... :)
...ok, I'll answer. Don't know true km's, but it had 150 across all six when we did a compression check a couple of months back. Haven't done a leak down test though. Might do another test to see if anything has changed.
And it was running about 1.2bar
Now I have had time to think about it - I think its almost certainly oil past the turbo seals since there is oil in pipe coming off the compressor side of the turbo (ie in the piping marked 'twin turbo') . It can't have got in there any other way can it?
And if this is the problem, then the question is: what oil pressure "should" the turbo oil line be restricted to? Has anyone got an actual figure? (that way I can put a gauge on it rather than just picking a size of oil restrictor out of the hat)
blowby, thats the usual one. if the rear seal is gone then it wont have oil in the intake side
sounds like you might just need a catch can :) simple fix and inexpensive.
To test, just get a coke bottle or something and see what happens, take the pipe off that goes back into the intake
Yup. Well. Now she's had a compression test and it looks like I've all but lost number 2.
The question on my mind now is if I had have had a catch can, might this have been avoided?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
