yeh lots of good sugestions here, thanks guys, i definately think i'l go with getting more flow through exhaust, as i have 3"atm maybe try upgrade to 3.5" get rid of the cat, go for some dump pipes and cams and c how we go.. maybe i'l be happy with the extra power, 350 by the sounds of it might be a bit out of reach.. so mybe i'l have to be satisfied with 320 or so... unless my engine blows sometime soon then i might go all out with a rebuild and try and push it hard.. :)
but thanks for the sugestions
Edited by Skorj
poncams and cam gears have been mentioned, i was under the impression that the poncams were spot on and you didnt need cam gears?
a 3.5incher plus a straight through cat will work wonders! definitly sort the exhaust first, as even if you put on bigger turbos later the exhaust will be done already. Get the most of the GTSS's and when your bored of that, rebuild motor and throw on GTRS's and easy 400+awkw!
gtr you need adjustable cam wheels big must trust me we made over a 100rwhp tuning cams
pete
ps plus you can change the characteristics of the power curve
Hey Skorj
I have a similar output on my R32 GTR and I'm running R34 N1s (292awkw and 302rwkw) with PFC and a full engine rebuild. I'm only running 1.2bar (18psi) – which is the safe limit of the N1s so I'm told
I do not have 700cc injectors or 80mm AFMs, but I do have a Tomei fuel pump and SX fuel regulator, and I have done a port and polish of the head.
My std injectors limit my output at this point – and can hit 100% duty cycle at the top of 3rd gear (no flames pls – I'm getting bigger injectirs – OK)
I also have 3.5" catless exhaust with split (HKS style) dumps
My next power upgrade will be
RB25 AFMs
Apexi 80mm suction kit
700cc sard injectors
Tomei poncams
An I expect to get 350awkw – easy
I ?may? Also include a bigger FMIC just to be on the safe side.
AND – no it's not laggy AT ALL !!!
Edited by itbmils
sweet, u just got my hopes up a bit itbmils, hopefully if i go the 3.5" catless zorst, fuelpump cams, and i will eventually need a rebuild...
i might be able to get to my 350 goal,
anyone have recomendations for a efficiently priced 3.5"exhaust? should i go for a jap name like an hks, or just go to the local zorst shop and get em to custom make up a nice straight through zorst?
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
