this particular rb20 comes on boost at 5000rpm and makes power untill 6000rpm, not good for drift, the 6000rpm sign off is not head flow related, rather cam related so the 26 cams should help there. an engine that signs off early is not as bad as an engine that comes on late. in drift racing, response is everything. hence the 30 bottom end.
  • Replies 48
Are you 100% sure its headflow/cam related.
Does it have a really nice equal length manifold?
Run a crap manifold and you WILL see top end power fall over early.
Roy's RB20DET running the TD06-20G is an extremely good example of this, power holds up really really well compared to other 20t's. The only real difference appears to be the exhaust manifold.
Edited by Cubes
pulled everthing apart yesturday, its amazing how small those rb20 valves are. i priced an rb25 engine today but with big injectors i just havn't got the money at the moment. it dosn't look like too much work to get the 20 head to fit so i think i'll just build a strong bottom end and just whack the 20 head on until i can afford the 25 head.
what timing belt and idler pulley should i use, whats the best way to get the block lower in the engine bay? what do i need to do with the oil restrictors?
ok ok ok a mate bolted a rb20det head onto a rb30 bottom end in a r31 skyline.. (old shitter just for a joke)
the head will bolt straight on how ever the compression ratio worked out to be between 11.5:1 and 12:1
not exactly good for turbo application.. sure excellant response
made 12psi by 1800rpm from memory with standard turbo that motor is now dead.. but it was worth it for the time that it lasted and it did a great skid lol
Wazz
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
