G'day, I tried searching and couldn't really find what I need.
Basically today I took off the AAC valve on my RB20 and gave it a good clean with carby cleaner. I removed the whole thing (4 Hex bolts) and I un-screwed the two screws holding the solenoid looking thing on. I gave the whole thing a clean, and put it all back together and reconnected it, started it, and it idles very high, and when it's warmed up it can't sit on it's high idle (2000rpm), it continues surging from 1000-2000 when it gets warmer.
When its running I can disonnect the connector and it stills continues what it's doing without any change. So I guess I put it all together incorrectly? Can someone give me some pointers how to put it back together correctly? Maybe I have put the plunger the wrong way or something silly like that?
I have disconnected the battery for a day or so to reset the ECU, incase it isn't used to a clean valve or something like that
Cheers all
Edited by GTAHH
https://www.sau.com.au/forums/topic/93366-aac-valve/
i had the same problem and finally found it was actually my air regulator (slightly stuck open) mine was a 32 GTR so i dont know where your air regulator might be
but it could be worth checking that out
Good Luck
RellikZephyr
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1687487
The air regulator can effect the idle like this and is located behind the injector fuel rail about 3/4 of the way back towards the firewall. I would not advise cleaning this or if you do be very careful. There is a nut on it covered in locktight and is there to adjust the gate inside for how much air to alow past. You can successfully clean this item without too much drama but try not to play with the locktighted nut. If you do have to play with it, set it so the gate is fully open. Have you had your TPS or MAF meter checked?
Also give the entire intake system a good cleanout to ensure no gunk is present on the throttle body, MAF meter or any of the pipework.
Also check to make sure you don't have an air leak somewhere. You can use carbi clean to locate the source of any air leaks.
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1687594
how does carby cleaner find leaks? does it affect idle or something when you spray it on a vac leak?
Edited by midnight
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1687786
Yes, it effects idle when you spray it over a vacuum leak.
Just another quick question....you did reset the idle after cleaning the thing out didn't you because if you have the screw wound all the way out it will leak air past and cause it to hunt like that.
Try winding the screw in all the way - it should konk out when it's almost all the way in, then just wind out slowly until idle comes good.
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1688588
Yeah champ just left it disconnected for over 24hrs to test if that might fix it. Will try and get into it tomorrow hopefully with good news. I will definatley try winding in the idle screw if it still continues before I try all the other steps.
Hopefully comes good
Cheers again
Edited by GTAHH
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1688679
I've wound it all the way in and it seems to drop idle by around 300rev's, so its around 1500 and it doesn't seem to be doing the surging as much anymore it's just got a 1500+ rpm idle :P very strange. It still does the surging but not as often
I took off the hose going to the reg valve (while running), and the idle settles down to just above 1000, when I block the part of the T-piece going to the reg valve(where the hoses separate to go to the aac and the reg valve) the revs increase.
So i.e with the engine running and with the hose to the reg valve not connected and not blocked it runs a lower idle around 1000. If I block it, than it runs a higher idle.
So that means the reg valve is stuck open?
Edited by GTAHH
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1689204
Oh and when I block the hose going to the AAC valve it runs like crap and stalls?
This normal?
Each time I take the AAC assembly off and re-assemble it, it does something different, sometimes idles higher, sometimes doesn't surge.
Cheers!
Edited by GTAHH
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1689314
in my r32 gtst i took it off the other day to check the spring was still sitting straight because it did the funny idel jumping thing once and yerh was still ok but i fiddled with the idle adjuster screw + shaped faces out ways when the acc is on towards the drivers side so maybe if you take your aac of again check the spring and put it pack on start the car and adjust it from there to where you want the idle to sit remember it idle a little higher when cold so set it to about 1,000rpm maybe a little lower
cheers
Edited by gt-t_r34
https://www.sau.com.au/forums/topic/93366-aac-valve/#findComment-1691370
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
