Was having a bit of fun with my fren in princess hwy. When i shifted to 2nd gear and rev around 6500rpm my engine suddenly juz lag on me..... How should i say it.... The feeling was like the same feeling when u release ur clutch too early and u get the choke. But it was on 6500rpm and the car is around 90km/h.
Is this wat they call PING? or my piston ring is f*ked? Anyone got the same experience before? Should i send my car to a mechanic? Can they detect anything without tearing the engine block apart ??
Help will be really appreciated.
Thanks
https://www.sau.com.au/forums/topic/93367-engine-screwed/
Pinging is also known as knocking basically its an uncontrolled detonation.
When your spark plug fires it has a controlled/smooth burn of the petrol but when its really hot per say then the fuel will ignite before the flame from the spark can get to it, combusting suddenly before the optimum moment aka the Power Stroke.
This uncontrolled detonation creates a shockwave which reverberates in the chamber creating a "Pinging" Sound. The Pinging sound is distinctly a metallic sort of pinging sound.
And thats what Pinging is :P
If you want to check if your Piston rings are f**ked do a compression test dry & wet obviously. If you get two totally differnt results on a cylinder from the Dry compared to the wet, then your rings could possibly be screwed.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1685031
I would recommend firstly removing the spark plugs and having a look at the electrode. The electrode should be brown to greyish white in colour and should show no signs of wear. If all is well there then my best guess without testing the car would be that your coil packs may be showing signs of failure. If the electrode is warn in any way it would suggest possible detonation.
The sound of detonation (Pinging) is very distinctive and my best description would be filling a tin can with marbles then shaking it like crazy. But then add exhaust, road noise and sound deadening and I am sure you get the idea. If this is the case it’s time for a tune and possible fuel system upgrades.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1685157
My car is running fine now.
jmac - My car is running with standard ECU.
paulr33 - Boost gauge still showing that it on 0.5 bar when rev. So probably not the turbo problem.
By the way, do u think shifting gear around 6500 RPM is appropriate. I mean it is too early or push the engine too hard oledi. Juz want to be on the safe side.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1687961
it just sounds like you had a AFM cut.
same as when you turn the boost up enough that the AFM can't measure the air coming in fast enough and you get a engine cut sort of thing.
where the accelaration stops instantly for a split second and the whole car jerks.
that's what probably happened.
I doubt you broke anything.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1689231
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
