Was having a bit of fun with my fren in princess hwy. When i shifted to 2nd gear and rev around 6500rpm my engine suddenly juz lag on me..... How should i say it.... The feeling was like the same feeling when u release ur clutch too early and u get the choke. But it was on 6500rpm and the car is around 90km/h.
Is this wat they call PING? or my piston ring is f*ked? Anyone got the same experience before? Should i send my car to a mechanic? Can they detect anything without tearing the engine block apart ??
Help will be really appreciated.
Thanks
https://www.sau.com.au/forums/topic/93367-engine-screwed/
Pinging is also known as knocking basically its an uncontrolled detonation.
When your spark plug fires it has a controlled/smooth burn of the petrol but when its really hot per say then the fuel will ignite before the flame from the spark can get to it, combusting suddenly before the optimum moment aka the Power Stroke.
This uncontrolled detonation creates a shockwave which reverberates in the chamber creating a "Pinging" Sound. The Pinging sound is distinctly a metallic sort of pinging sound.
And thats what Pinging is :P
If you want to check if your Piston rings are f**ked do a compression test dry & wet obviously. If you get two totally differnt results on a cylinder from the Dry compared to the wet, then your rings could possibly be screwed.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1685031
I would recommend firstly removing the spark plugs and having a look at the electrode. The electrode should be brown to greyish white in colour and should show no signs of wear. If all is well there then my best guess without testing the car would be that your coil packs may be showing signs of failure. If the electrode is warn in any way it would suggest possible detonation.
The sound of detonation (Pinging) is very distinctive and my best description would be filling a tin can with marbles then shaking it like crazy. But then add exhaust, road noise and sound deadening and I am sure you get the idea. If this is the case it’s time for a tune and possible fuel system upgrades.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1685157
My car is running fine now.
jmac - My car is running with standard ECU.
paulr33 - Boost gauge still showing that it on 0.5 bar when rev. So probably not the turbo problem.
By the way, do u think shifting gear around 6500 RPM is appropriate. I mean it is too early or push the engine too hard oledi. Juz want to be on the safe side.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1687961
it just sounds like you had a AFM cut.
same as when you turn the boost up enough that the AFM can't measure the air coming in fast enough and you get a engine cut sort of thing.
where the accelaration stops instantly for a split second and the whole car jerks.
that's what probably happened.
I doubt you broke anything.
https://www.sau.com.au/forums/topic/93367-engine-screwed/#findComment-1689231
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
