I'm thinking about getting come HPC coating done and want to do it all in one hit.
For me the HPC will serve 2 purposes:
1. reduce heat since i'll be running a bar or so of boost
2. It looks good.
What should I have done to cover both bases?
Will it give me a increase in performance?
What parts should I polish instead of HPC?
Lastly, i've never seen any pricing on HPC coating. What will it cost?
Mark
https://www.sau.com.au/forums/topic/9341-hpc/
Hi Guys,
I was looking at getting my exhaust manifold coated so I gave these guys a call, it's about $550 to get the exhaust manifold coated.
If your after serious performance then you should ceramic coat the exhaust manifold and turbo exhaust housing. HPC coat the intercooler pipes, most important is the intake manifold pipe.
I think that with a combination of HPC, cold air induction you will see a decent performance improvement due to the cooler intake temperatures. Don't forget that heat wrapping will provide similar results, but it doesn't look as good.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140502
I'm new to this process, but I understand the advantage of HPC and ceramic coat ( I always though that hot gas will run faster..), however does ceramic coat can apply on "any" surface? for example, I have a set of trust stainless manifold and mild steal..dump + front pipe, should I ceramic coat the them? or just the manifold?
I know the heat warpping, but does it capable to handle 1200+ temperture? thanks..
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140723
I've just ordered a stainless dump pipe, and have a Trust mild steel front pipe. I called HPC (www.hpcoatings.com.au) last week and the guy quoted me $66 per foot for piping. I figured that because hot gas travels quicker, and the next main restriction is the cat, that this would be enough of the exhaust system to do.
PS they need 5 days to do the coating.
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140896
sidewaymambo,
You can ceramic coat just about any metal surface, if it has already been used then they will need to clean it and bake it so that the ceramic coat will stick. Ceramic coating is best for exhaust manifold, dump pipe, front pipe and turbo exhaust housing. I think if you want to do intercooler pipes then either use heat wrap or HPC.
The heat wrap will work fine in high temperatures like on your exhaust manifold, just make sure you buy the right stuff, and not some cheap brand.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140901
Keep me up-to-date on any quotes you get for the HPC coating.
What sort of performance gains would I realise if I get the exhaust manifold, turbo exhaust housing and intake manifold pipe as VSPEC suggested? and has anyone got any ball park figures for this work - I cant call them while i'm at work.
I might leave them an email instead.
Mark
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141718
I'm with steve. If we can organize a group 'coating' maybe it will be cheaper. I will call them tomorrow and see if they will do a group discount, and if so start a new thread and will try and organise it with HPC. Not sure how we can logistically do it - send all parts to me and then to HPC? or send them individually?
If i organise it probably keep it to the Vic boys and girls, just it is easier than doing everywhere. I will keep you posted, check here and if i start a new thread i'll link it to here.
https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141955
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
