I went to dragstrip last night and managed dissapointing time of 13.8s, 109mph (175km/h)...car is r33 with bigger turbo (its T-57) making 347hp atw ON 15psi, and i expected at least low 13s...traction was shit 60 foot 2.478 sec, with shit trampio tyres at the back 18 inches 265 wide, tyre pressure at 40psi (stupid me checked today tyre pressure)...what do you reckon the car should do with this mph, and what launch methods u using, i managed best 60ft without much throttle at take off and whenever i upped the revs i couldnt do better time than 2.6 60foot...i noticed as well that gear stick was sticky on second run, i needed to push really hard few times to get it in third gear, still beat wrx hehe...what could the reason be? i suspect when car was brought here from japan while compliancing all the fluids have been changed except gearbox oil so it could be too old?
https://www.sau.com.au/forums/topic/93500-dissapointing-quarter-mile/
i have 225rwkw and got a 13.5 at 109mph... 60 foot 2.3 on 235/45/17
then the next week went back (same set up) and managed 13.1 at 110mph
then went back and got 12.71 at 111mph 60 foot of 1.93 on the same tyres...
just go back and practice...
by the way i launch at 6 grand
hope that helps
hope that helps
is that a 6000 dump or u let it ride a little
i ride it a little. best way to explain would be that i let the clutch go in one fluid motion over a period of about a second or a bit less.
don't hit the limiter it will die in the ass before you grab the next gear... your MPH indicates a mid to high 12 sec pass if you can get the 60ft time down to 2 flat...
I suspect your suspension setup to be at fault... common errors for drag are too stiff a rear suspension and too much neg camber at the rear as the car has been lowered? modern IRS cars don't like to be lowered or you will just fry the insides of your tyres... which is even worse with wide tyres... get some camber adjustment bushes should help get the beast off the line
i have a feeling if i had 50hp less i would have done better time
hope that helps
what revs is rev limiter at
suspension does feel stiff, its tein not adjustable suspension, no camber kit
it's all about the first 60 foot. 2.5 is way too high to be able to run a low13/high12. i am pretty sure it's just a practice thing. and lower your pressures to about 24 psi. that will help a shiteload :(
Dump the 18's get some sticky street tyres on some 16's,select correct tyre pressures,change over your susp for some 90/10 's pedders,take the spare and any thing else loose out of the car,i would lightly slip the clutch on initial drop, short change into second,dont drive to limiter in 2nd then give it all you have got in 3rd and hang on,drop into 4th if you need it.The biggest mistake every one makes is using too much 1st and 2nd gear these only result in excessive wheelspin- hence your slow 60ft times,3rd gear is the one that does the driving and you must get up into it as soon as posible!
Anyhow good luck with your future racing (remember is not the out right hp but the way in which you hook up! )
Regards,
SKYLINE (Kym)... B)
Edited by skyline
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
