I think the first thing to check is if it is dual 2 or dual 4 ohm voice coils coz a dual four will only run at two or eight ohms thus a monobloc and a dual two will only run at 1 or 4 so probably look at a two channel and bridge it.
Just out of curiosity how much are you guys paying for the suitable jaycar amps just so i know what sort of budget you are shopping with.
W3s are hot man especially in the ported box but don't feel bad about giving it 400-500 wrms they love it as long as its clean power trust me.
Run mine in the shop (JB HiFi) in qld off a 500/1 and it is tight as. If you really want to hear it sing try a jl e1400D (if its a dual 4) and you'll never go back. If its a dual two ohm (less likely) go to JB and check the prices on coustic 600S two channels for comparison to jaycar stuff they are good for 350wrms bridged and sound great on subs especially for under $300.
https://www.sau.com.au/forums/topic/93516-what-amp-to-use/#findComment-1688784
just to clear it up a dual 2 ohm sub will present a 4 ohm load if you run the two coils in series or 1 ohm if you run the two coils in parallel.
Same principle as wiring two single voice coil subs you can only double or half the impedance with each addition so two four ohm subs wired together will run at 2 or 8.
So the jaycar two channels are okay if the sub has two ohm coils, the audiobahn A8000T will give give 400rms at 4 ohm or 800 rms at two ohm. Mass_iv has also got dual 2 ohm subs as both subs would be wired in series to four ohms and the two subs would be wired in parallel to the amp to bring it back to two.
https://www.sau.com.au/forums/topic/93516-what-amp-to-use/#findComment-1693499
go to jaycar and get their new line of monoblocks, set you around ~$800
should be able to crunk out 800 watts RMS @ 2 Ohms, if your sub is dual 4 ohm
thats overkill for that sub, but in the future if you get a sub with higher power requirements it would be useful.
https://www.sau.com.au/forums/topic/93516-what-amp-to-use/#findComment-1729316
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
