  • 1 month later...
hi guys, ive read through the whole thread and was wondering if anyone knew what rotors (DBA Part No would be great!!!) fit using the ceffy brake set up but using a 5 stud conversion. My mate got a 5 stud conversion kit, and wants to keep the rest of the ceffy shit there. As it stands he is just gunna drill out rotors. Does anyone know the 4 stud ceffy rotor part no??????
If anyone is interested I found out that Cefiro brake pads are also the same as the Y30 Cedric ones, for those who are too pov to afford better brakes, lol.. Like myself. :wacko:
Edited by AdMan
  • 1 month later...
yea i noticed much greater pulling power when boost kicked in and esp after 5000 revs when i was finding mine was dropping off as a result of the increased boost i had, and there was no lag difference. Plus they are rated for up to 200kw ...so i figured i would try it instead of a big front mount. At the moment i dont think i will be going over the 200kw mark so i thought it was the best option for now. There are acouple of threads in the forced induction section on this.
http://www.skylinesaustralia.com/forums/in...l=r34+sidemount
For those interested, see below the size difference of the A31 stock coller to the R34 unit... as resin has previously mentioned, it is a straight swap, only problem I had was that needed to trim down plactic surround to account for the larger dimensions of the cooler. Overall was a cheap and simple upgrade.
Edited by skypy12
  • 3 weeks later...
Just thought I'd add this from another thread, in keeping all the useful parts information in one thread.
This is for the gas struts that hold your bonnet up.
here you go guys the savior to all your dramas yeah i was going to get regas but mine were so shagged the guy could not do it but new is better
monroe part # ml4371
Thanks for that info, pretty common with the ceffys. Great thread this one is too, pitty about the chit chat in here though, could be cleaned up a bit just leaving the facts
  • 1 month later...
Just converted my cef to an R33 radiator, and can confirm that it was minimal effort.
Basically you use the factory R33 mounting rubber and brackets. Then its a matter or using the factory hole for the top left bracket, and making a new hole on the radiator support for the top right bracket.
The radiator does sit a little higher than the factory jigga, but not enough to hit the bonnet. I've got my factory underbonnet padding, so it just squashes that a touch.
  • 2 months later...
Swaybars for the Cefiro specifically can be purchsed from Selbys (http://www.selbys.com.au/)
Nissan Cefiro 88-03
F Swaybar-h/duty Blade adjustable SNF702A 27mm Replacement type
R Swaybar-h/duty Blade adjustable SNR26A 22mm Replacement type
R Swaybar-X h/duty Blade adjustable SNR26CA 24mm Replacement type
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
