hey. been looking around these forums for a fair while, but never actually signed up. anyways, i thought it was about time.
I just bought a c210 skyline coupe.
was wondering what can be done to the L24 to give it a bit more poke..
Still gotta get the car past rego sometime within the next few weeks (which shouldnt be too hard..) but after that it will be an ongoing project.
here are a few pics..
https://www.sau.com.au/forums/topic/93528-c210-coupe/
the chassis number (im guessin thats the VIN, right?) is
KMGC210 - 000395 .. or something similar..
was built 12/77 according to the plate on the firewall.
Edited by Jono_c210
https://www.sau.com.au/forums/topic/93528-c210-coupe/#findComment-1689370
I used to have one of those in "Jaffa" orange.
Rust in those are a bugger (especially around the rear wheel arches and boot) but mine was very reliable. I remember I bought the last new old stock window rubbers for the rear windows from Nissan Australia. It really suprised me how many old parts Nissan Australia still carries.
All it needs is a RB25 DET and they would be great!
https://www.sau.com.au/forums/topic/93528-c210-coupe/#findComment-1689958
well hello long time no see :lol:
i seen this beast in the flesh and as for the rust it aint that bad just the sills under the door well if there were a rear door that is and a bit in the boot rubber near the lock.
needs the window seals though.
i gotta say for a car made in 77 it has the lot, gotta love the stock boost guage even though it aint boosted :lol:
i would say a set of xtractors for sure and a decent zorst, and a bigger carby.
keep us updated Jono
SSS_Hoon
https://www.sau.com.au/forums/topic/93528-c210-coupe/#findComment-1695508
Heres a few new pics from the last couple of days :D
one question i have.... Does ANYONE know where i could get the rubbers that go inbetween the front and rear window??? any help with that would be greatly appreciated.
New head unit. hidden away in the glovebox :)
Anyone know what this button does?^ it says 'REC'
Origional datsun floor mats?
L24 with factory power steering and a/c
https://www.sau.com.au/forums/topic/93528-c210-coupe/#findComment-1729904
anyone got any idea where to get the rubbers between the windows??
I got a set 8 years ago from Nissan Australia and that was the last set in NSW but if you ask nicely maybe they still have set interstate?
I also managed to get some rare alloy wheel centre covers for another old Nissan a couple of years back which they managed to supply. You never know what they ahve in their warehouses. If not try Rare Spares (I think American Autoparts in Sydney are their agents now). Otherwise the wreckers yards or ebay.
Good luck
https://www.sau.com.au/forums/topic/93528-c210-coupe/#findComment-1732216
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
