It shouldnt do any damage to your suspension, maybe your wallet though, depending on how much the springs are. Your shocks should handle it, your guards may need to be rolled depending on how stiff the springs are. You should really get some coil-overs.......most companies would do you a fairly decent deal for second handies most times $750 give or take $100 or so for Teins
Thanks mate appreciate it
Yeah the springs are $400 so its not that bad they will lower the car 2"inchs
I was just concerned if it will damage my shocks cause the springs are lower that the factory stockies
Coilovers not as yet cause that will do damage to my wallat lol
LOL! yeh it did to mine, but i upgraded my camber arms front and rear at the same time, and that was a huge difference...fully adjustable. But thats not a bad price man, $400 and lowered 2 inches you should be sweet and the ride will look meaner....find out how stiff the springs are if they arent too hard, suggestion is to roll your guards
Mate, i think you have the wrong idea, have you actually tried this?
And to r33zilla your shocks are probably already stuffed, and if you put 2inch low springs in i can assure you it will be much worse.
If you care about handlng you wont lower the car more than 1inch.
Also jap coilovers are not suited to most peoples uses, and you could most definetly get better ride and handling from shocks and springs you choose yourself locally ie the groupbuy at the moment, or like myself bilsteins and whiteline springs.
go to https://www.whiteline.com.au/ have a read of the article related to skylines.
Springs lowered 2" will have to have higher spring rates (usually around 30% minimum), otherwise the suspension will bottom out due to the reduced travel. Standard (new) Skyline shocks don't handle the standard spring rates very well. Well used shocks are even worse, so there is no way they are going to control springs with ~30% higher rate.
When you lower an R32/33/34 Skyline they get excessive negative camber. This results in lousy handling due to the reduced tyre contact patch and wears the inside of the tyres rapidly. This is what is needed for each height increment, measured from the centre of the wheel to the guard verticaly;
Standard (new) height is 380/370 mm front /rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Check out the R33GTST Whiteline/Bilstein Group Buy for more details;
http://www.skylinesaustralia.com/forums/in...showtopic=85467
:P cheers :)
Edited by Sydneykid
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
