To clarify, I can't hear the noise inside the cabin when driving. It is only really noticeable when parked and most certainly when the bonnet is up.
Initially, I was concerned about the noise, thinking that something was "wrong". Since then, I haven't been overly conscious of the noise.
Edited by clayoth
Your belt has been overtensioned. No belt should be noisy, no matter what brand it is. If you overtighten it....it will hum.
I have installed Gates, HKS, Greddy and Nissan ones and none of them make noises. You just have to know what you are doing.
It is spring tensioned but is also able to be manually tensioned. You never rely on the spring on the tensioner bracket to provide full tension. It always has to be manually done to ensure correct tension is applied.
i just got my gates one put on,bit more noisy but not to bad,likje the noise if anything...the bloke at advan said i should most defintaly change both tensioner bearings,but i also did pump to
