All these turbos have the same size exhaust wheel. exhaust housings differ in size Here is a list of smallest to biggest exhaust housing.
RB20det
VG20det
RB25det
VG30det
Compressor covers in order of smallest to largest:
RB20det
VG20det
VG30det
RB20det
The compressor wheels are all different sizes meaning we must keep a wheel with its original compressor cover..
What is the best combination?
I was thinking a complete RB25 turbo with a VG30 exhaust housing.
So it will in effect it will be a VG30 turbo with a RB25 compressor and compressor cover and therefore produce more airflow for the same shaftspeed... Is this correct?
The aim is to produce a turbo that will provide enough airflow for a 2litre engine to produce 170odd rwkw at 11psi.
And no a RB25 turb won't do it as have one on the car ATM and it makes 149rwkw with auto transmission. manual would make more.
Has anyone done a rb25 front with a VG30 rear? if so please post your results:)
hey mate, there was a fair bit of discussion as to using the vg30det rear recently. they are bloody hard to find though...
http://www.skylinesaustralia.com/forums/in...topic=78983&hl=
some decent results here
Your best bet is the R34 GTT Turbo.
Its the largest of all turbo's.
The VG30DET turbo is a Rb20DET turbo with a larger RB25 sized comp cover and larger R34 sized turbine housing. Meaning if you bolt the larger comp and turbine housings on to a RB20DET turbo it will be EXACTLY the same as a VG30DET BB turbo.
The R33 runs the smaller rb20 style turbine housing, from what I've measured the rb20 series 2 and R33 rb25 turbine housings are the same size. Only difference being the compressor and cover is larger with the rb25 unit.
The R34 and VG30DET BB turbo's run the same turbine housing. 'OP6'
Edited by Cubes
Thanks for the heads up Cubes,
Ok I will start hunting for a VG30DET or R34 turbine housing with "op6" written on it.
Is the R33 and R34 compressor housings and wheel the same size? I know the R34 comp wheel is polypropelene and the R33 is an alloy but are they the same size?
Only the Series 1 Rb25DET compressor wheel is metal. The series 2 is the same as the R34 being 'plastic' or polypropelene as you said. So becarefull with the identification, an R33 Series 2 turbo will look like the r34 turbo but has the smaller turbine housing.
I assume nissan went the larger turbine housing on the R34 due to its neo variable cam timing. Obviously improving low end torque and turbo spool, as a result a larger turbine can be used with no ill effects.
I was thinking the other day.. Say the bearings went, the compressor wheel smashed in to the housing, if it were the plastic wheel would the plastic shavings do less damage to the motor or possibly none?
The metal compressor wheel, your poor motor has no chance in hell, metal bits entering the motor is an instant bore score and compression loss. :D
That being said I think the best turbo for the rb20det will be the R33 series 1 with the smaller turbine housing to help the mid range. Maybe look at the series 2 with the plastic wheel to help spool on the 2ltr.
No matter what your going to need some decent boost in the rb20det to get it making decent power. Especially with the power sapping auto.
14psi with an rb25 turbo and tuned ecu should see 190rwkw with a manual.
Being an auto.. pull what? maybe 15rwkw off it?
Edited by Cubes
Its actually going on a VG20det and replacing the standard VG20det turbo. and yes the auto sucks!
I have had a RB20det cefiro with the following turbos.
RB20turb - putting out 154rwkw
RB25series1turb - putting out 179rwkw
RB25 series 1 turbo with VG30 exhaust housing putting out 204rwkw
I will take some pics and measurements of the VG20det turbo when it comes off.
If the R32 s.2 and R33 s.1 are the same housings, do they share the same ID on the castings, and was this a side-by-side examination please?
cheers
"i have a s2 rb25 turbo with vg30 exhaust housing and i have 262.4 hp atw
this is on an rb20 manual"
Thats interesting master_d. At what rpm does the boost come on? Would you say it is laggy at all on the RB20?
I'm trying to make a decision on a new turbo for the rb20 at the moment. I was looking at the highflow option, but Michael from GCG said that the RB20 highflow would run out at around 220-230rwkw. He also mentioned that an RB25 or VG30 would be quite laggy on the RB20 due to the flow restrictions of the engine.
I was then considering a RB25 highflow with a RB20 turbine housing (I havent talked with him about this yet) to reduce the lag. This doesn't seem worthwhile if the turbine housings are basically the same size as cubes has mentioned.
Any ideas what is the best highflow combination for the RB20det guys??
(All supporting mods present of course).
I think the standard turbo on the RB20DET, but High Flowed.
As they have said, the RB20DET can only swallow a certain amount of air, short of building the engine strong and pumping a truck load of boost into it.
So, get it highflowed, keep some sembalance of response and stick with 220 rwkw.
After all (no offence intended) it's only 2.0 ltrs and you can only get a certain amount out of 2.5 ltrs.
The 2.5 ltr is 25% bigger, there fore, can swallow 25% more air at similar boost and so on.
BASS OUT
I was going to go for the highflow to avoid installation costs, being able to keep the same lines and all.
GCG basically said that the turbo would be limiting the power output in the case of the highflowed RB20 turbo. Thats why i though a larger compressor housing with the same turbine housing would allow for larger power without bringing in tons of lag.
Michael said the best option for the rb20 is actually a GT3040, but with a .48 turbine housing. (They bore the housing out to fit the larger wheel). The small turbine housing causes quick spooling and the large wheels and compressor housing allow for large power.
I was going to go for this option at $2450 for the whole internally gated system (including lines and actuator), I was just concerned about installation costs. Would need a spacer plate, new elbow joint to intercooler, new joiner fron afm to compressor inlet and a new flange on the exhaust (which could be an issue since i have a split dump).
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
