Nissan Vh45de Engine
GTR_Junkie
 Share
Does anyone know if this engine will fit into any of these cars?
Depends on what you mean by 'fit'. It's certainly not a bolt in proposition, but with enough time and $$ anything can be done. One of these has been shoe-horned into a 240Z. One problem is that there are no manual gearboxes that bolt straight up, so an adaptor plate would be required. Of course, doesn't matter if you stick with the auto.
Yeah, don't like your chances. John looked into that but if you saw the custom headers that had to be made to squeeze past the chassis rails then the turbo option quickly evapourates. Thats why he went down the supercharging path.
There's a VH45DETT in a S14 thats being built here in QLD, running twin XR6 turbos, custom plenums etc...
Very tight fit, turbos are located behind the headlights, inner guards have been cut to make way for the exhaust manifolds etc...
Be interesting to see how it goes once finish :)
There is a 300zx up here with one in it.  He has used the 300zx manual gearbox with it, as thats what was in the car to start with from memory.  I guess the major problem you will have is with the width, not so much the lenght.
Is that the orange one?
Yeah the S14 I mentioned is running a VG30dett box aswell.
Twin xr6 turbo's on a 4.5 litre will see decent boost by maybe 5500rpm..
Haha, be an interesting ride for sure once on boost.
Ok, well i was thinking to fir the engine up into a car, leaving the engine standard using Twin T04Z and the other assosciated bolt-on's, and once it grenades just removed and re-build it or buy another engine.
Should be good for over 1000hp me thinks, the car will be used as a drag car but i want to keep it registered and engineered as i would like to be able to drive it on the street every now and then
Cheers
 Share
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
    • I would say 100% that it doesn't matter at all. I have an Al bonnet and I drop it sometimes, push it others. Have done so for 25 years and there's no way to tell that either has caused any problems (because there are no problems).
