Calling all NTers
Majanal
 Share
sweet thanks RBNT, I got the same msg from the track, first meeting is 24/12, too late unless my contract up here extends.
Of course, If I'm still in NT I'll have to give it a go :)
What sort of times was your GTR doing around the track?
Hey Duncan,
Ran a 1.27 but had overheating probs (track temp is very very high) and ic piping blowing all the time. Track surface is very good and gets even better as time goes on. You will find your best times are after the club cars go through, bit more rubber on the track (thanks dave). I suggest if you go out on the track for the first time you take it pretty easy all over. After you are familiar with the track the only place's to watch are the entry to clubhouse corner - some bumps just prior to the braking area so go in straight and brake hard late. The hairpin is a good one also, I have spoken to the top club car racer about how to go about this one but it is still a mystery to me. I felt quickest going through in 2nd and clutching it out of the corner to get a little sideways and make the attessa work. After the hairpin you will come up on the terrace turn which should be flat chat in 3rd. The sandtrap corner can be tricky - go wide and turn in sharp (hopefully you are not still flat out in 3rd) to wash off a bit of speed (atessa induced cornering out of the nissan bible of circuit racing) and prepare yourself for a bit of a rest down the main straight. Oh, dont forget to brake(^^) you will work out your own braking marker for that one. Will not be in Darwin to see you as I am travelling down to the ACT for a wedding at the time. All the best.
ken
  • Replies 73
Mondays cool with me Ken
And sorry Candy Bars is a personal Joke was supposed to be a PM
Andrew
Thats OK Andrew - death will come swiftly for u!!!! :D JOKEJOKEJOKE, Good to hear you will be there!!!!. Well there seem to be a few interested parties for the cruise - now all we have to do is get ourselves organised. Let us know whats going on by using this thread or PM any of the Darwin group and start the email trail - or PM SIM88. Where are you Simon?????????????
:D
Ken
  • 1 month later...
I am from Palmerslum, would like to meet up with one of you gts-t r33 drivers in darwin.
Supercharged my rb30 awhile ago and would like to see how she goes. My mate wont race me because he came for a ride just after it was in and refuses to have a go.
G'Day Static,
Come out and meet the mob at the drags, it will be a good nite!! Whats the rwkw figure for the 30???
Cheers,
ken
  • 3 months later...
Arrived a couple of months ago with my '89 R32 GTR - which I've yet to get on the road (buggered turbos). Rebuilt with steel and BB
Looking for the odd spare part from an R32as well like the flat plastic underbody BOV protector plus odd screws etc.
And an oil filter reloation kit. Any of you guys have any opinions on running oil collers up in this part of the world? Necessary?
Seen a fewskylines on the roads including the white "Zilla" and met the R33 d00d at Japanese Motor Spares in Winnellie (nice car, nice bloke).
Cheers,
John
  • 2 years later...
  • 5 months later...
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
